Audio Research VSi60 Integrated Amplifier (Used)
Condition 8/10. Sound 10/10
Price RM 9800 Nego
No more Warranty. With Remote Control
Contact: Andy 019 211 2566 Scott 019 3636369
POWER OUTPUT
50 watts per channel continuous from 20Hz to 20kHz. 1kHz total harmonic distortion typically 1.5% at 50 watts, .05% at 0.1 watt. Approximate actual power available at “clipping” 52 watts (1kHz). (Note that actual power output is dependent upon both line voltage and “condition” i.e.: if power line has high distortion, maximum power will be affected adversely, although from a listening standpoint this is not very critical.)
POWER BANDWIDTH
(-3dB points) 12Hz to 70 kHz
FREQUENCY RESPONSE
(-3dB points at 1 watt) 1.0Hz to 80 kHz
INPUT SENSITIVITY
0.47V RMS Single-ended for rated output. (32.5dB gain into 8 ohms.)
INPUT IMPEDANCE
50K ohms Single-ended
OUTPUT TAPS
8 ohms, 4 ohms
OUTPUT REGULATION
Approximately 2 dB 8 ohm load to open circuit
OVERALL NEGATIVE FEEDBACK
7dB
Price RM 9800 Nego
POWER OUTPUT
POWER BANDWIDTH
FREQUENCY RESPONSE
INPUT SENSITIVITY
INPUT IMPEDANCE
OUTPUT TAPS
8 ohms, 4 ohms
OUTPUT REGULATION
7dB
Perfectphf- Frequent Contributor
- Number of posts : 146
Registration date : 2018-03-15
» Audio Research VSi60 Integrated Amplifier (sold)
» Sold - Audio Research VSI60 tubed integrated amplifier (Used)
» Audio Research VSi60 Vacuum Tube Integrated Amplifier
» Audio Research VSi60 vacuum tube integrated amplifier
» Sold - Audio Research VSi60 tube integrated amplifier (Used)
