Solid Tech Hybrid Rack System - 3 Shelf
Solid Tech Hybrid Rack System - 3 Shelf Empty Solid Tech Hybrid Rack System - 3 Shelf
Post by raymond88 Tue Oct 01, 2019 11:44 am
Item: Solid Tech Hybrid Rack System - 3 Shelf
Condition: 8/10. Item is in excellent working condition.
Price: sold
Solid Tech Hybrid Rack System - 3 Shelf X151
Solid Tech Hybrid Rack System - 3 Shelf X248
Solid Tech's Hybrid comes from a long heritage of award winning rack engineering and features all the top state-of-the-art engineering qualities that you would expect. Most A/V racks on the market are pre-designed for one assemble, either as a single rack shelf, 2-shelf, 4-shelf etc. There is no flexibility to change or adapt. The Hybrid's latest developments allow flexibility like never before. Starting for example with a 4-shelf vertical rack you can easily reassemble with the focus on horizontal expansion such as a two 2-shelf racks side by side. If needed at a later date you can build vertically again while keeping the horizontal foundation from earlier. With this type of flexibility there are endless options to explore; meaning you can design the optimum A/V rack and tweak according to any changes you wish to make without any loss of platform-stability or support. FOUR BUILDING BLOCKS Ingenuity is hard to define, but you know it when you see it. The design process has revealed that only four building blocks are necessary to perfectly adapt the rack design to most A/V systems. The four building blocks are comprised of: the shelf-kit, 200mm corner-pillars, 275mm corner-pillars and finally 350mm corner-pillars. ENHANCEMENT WITHOUT COMPROMISE It is widely accepted that resonance control is essential in order to eliminate spectral contamination distortion. Resonating support systems cause masking of low level information and coloration, emphasizing some frequencies and reducing others. Most of the materials and techniques used in the conventional racks and support systems have unacceptable drawbacks and are not suitable for high-end usage. Very few structural materials deal efficiently with the requirements of both rigidity and dampening. The ideal audio support platform has to be both uniform in structure as well as rigid for its size and shape. Price listed is for a 3 shelf without level as in the picture on main page . A single shelf is $680 for 8" , $720 for 11" and $760 for 14". Add $40 for shelves with level.
https://www.solid-tech.net/hybrid/
https://krispyaudio.com.au/products/solid-tech-hybrid-rack-system.html
https://www.dynamichomedecor.com/Solid-Tech.html
http://brooklynaudioinc.com/index.php?route=product/product&product_id=1636
Number of posts : 10093
