Marantz SR6012 9 Channel AV Receiver
Marantz SR-6012
Price : RM2,999
Call or whatapps : 010-2225990
_____________________________________________
9.2 Channel Full 4K Ultra HD Network AV Surround Receiver with HEOS
Key Features
Powerful 9 Channel Discrete Amplifier and Eco Mode
Latest HDMI Connectivity; HDR, Dolby Vision, HLG, and HDCP 2.2 Compatible
With 8 HDMI inputs, including one conveniently located on the front panel for quick connection of video sources, and triple HDMI outputs, the SR6012 has an advanced video section supporting the latest HDMI specification, including 4K Ultra HD 60Hz video, 4:4:4 Pure Color sub-sampling, BT.2020 and HDR (High Dynamic Range) pass-through support on every input. Dolby Vision compatibility, as well as HLG (Hybrid Log Gamma), new HDR format for broadcasting, pass-through capability are newly supported.
It also features HDCP 2.2 compatibility, for 4K Ultra HD copy-protected content, on all HDMI inputs making it ready for the next generation of Blu-ray disc players, set-top boxes and 4K Ultra HD streams and downloads. The video processor can also upscale SD and HD video content to full 4K Ultra HD, breathing new life into your favorite legacy sources.
Three HDMI outputs are provided - two for the main zone, so you can run a TV and projector in parallel, and one for a second zone.
HDMI eARC Object-Based Audio Support
eARC (Enhanced Audio Return Channel) supports Dolby Atmos or DTS:X from your TV apps with a single HDMI connection for the simplest setup. This feature will be enabled via a future firmware update.
Built-in Bluetooth, Wi-Fi, and AirPlay 2 Capability
Featuring Bluetooth & Wi-Fi wireless streaming connectivity, the SR6012 is equipped with an advanced dual antenna transceiver system, for robust streaming even in congested urban environments. With Apple's AirPlay compatibility, you can enjoy listing to your favorite tracks wirelessly from your favorite iOS device such as iPhone and iPad.
HEOS: The Perfect Solution for Wireless Multi-Room Music Streaming
With built-in HEOS wireless multi-room technology, the SR6012 can become a key component of a HEOS system. You can enjoy your favorite music anywhere and everywhere around your home, controlled by the free HEOS app. Command music in every room from any device to play the same song in every room, or different songs in each zone.
The HEOS app opens the gate to multiple steaming services on your SR6012 or any other connected HEOS devices, including Pandora, Spotify, TuneIn Internet radio, Amazon Prime Music, iHeartRadio, SiriusXM, SoundCloud, Tidal, Napster or Deezer (*). You can also stream music from your phone, USB stick, or local network drives, all using the HEOS app, with favorites and playlist functions supported.
*Availability differs by area, subscription may be required.
Support for Major Voice Control Agents
Enjoy effortless voice control and total flexibility from the leading voice agents. Speak commands with Amazon Alexa , Google Assistant, Apple Siri and high-end smart home automation, Josh.ai. Ask to play your favorite music, turn the volume up, skip to the next track, switch inputs and more. Switch between voice agents, or pick a favorite to use — the choice is yours. Functionality varies by voice agent.
Advanced 32-bit D/A Conversion on all channels
For optimum fidelity and the widest dynamic range with lowest distortion, the SR6012 features advanced reference-class 32-bit AKM D/A converters on all channels. This ensures consistent high fidelity and precise channel matching across all channels for the ultimate listening experience.
High Grade Audio Components; Marantz HDAM and Current Feedback Topology
Featuring exclusive Marantz HDAM (Hyper Dynamic Amplifier Module) technology found on our Reference Series components, the SR6012 incorporates multiple HDAM modules which provide superior low noise wideband performance in an all-discrete configuration, compared to conventional op amp ICs. HDAM technology provides an ultra fast slew rate for true wideband response and maximum dynamic range to deliver optimum sound quality with today’s high resolution audio formats.
In addition to HDAM technology, the SR6012 also features Current Feedback instead of the typical voltage feedback configuration. A Marantz innovation introduced on our very first audiophile amplifiers more than 60 years ago, Current Feedback technology provides a wide closed-loop bandwidth and very high slew rate, delivering superior fidelity with wideband audio sources.
Advanced Audyssey MultEQ XT32
Equipped with the flagship Audyssey suite of features, the SR6012 features Audyssey MultEQ XT32 automatic room acoustic correction using advanced DSP algorithms. With the supplied measurement microphone, it analyzes the output of each speaker (including the subwoofers) at up to 8 measurement locations, then generates precision digital filters that optimize each channel for the bets possible sound.
Audyssey Dynamic Volume smoothes out annoying jumps in volume (such as TV commercials), letting you listen at lower levels while still enjoying clear dialogue, music and sound effects, while Audyssey Dynamic EQ provides full-range clarity at any listening level.
Audyssey Low Frequency Containment uses advanced psychoacoustic algorithms to deliver a full-range balance, including deep bass, but without disturbing close-by neighbors or those in other rooms, and features a multi-step adjustment.
Audyssey Sub EQ HT provides individual DSP tailoring of each subwoofer in a dual subwoofer setup, allowing deeper bass with improved definition when compared to a single subwoofer configuration.
The Audyssey MultEQ Editor App
The SR6012 supports the brand-new Audyssey MultEQ Editor App. Go ‘under the hood’, view and adjust settings for detailed tuning, customize the sound more precisely to the specific problems in your room, and tailor the sound to your personal preferences.
The Audyssey MultEQ Editor app, for Android and iOS, is available for purchase from the Apple App Store or Google Play Store.
External Control Capabilities
The SR6012 has a range of features to provide enhanced control and compatibility with 3rd party and custom integration solutions. For compatibility with other components there's a remote control input and output on the rear panel, along with a flasher input and a 12V trigger output, while for direct connection to external home automation and control equipment, there's an RS-232C serial port. The SR6012 can be set up and operated by a home computer via network IP control (via wired LAN or Wi-Fi), and also features Crestron Connected and Control4 SDDP (Simple Device Detection Protocol) for quick and easy integration with home automation equipment.
Price : RM2,999
[size=16][size=12]Immerse yourself in stunning 3D surround sound with the SR6012 AV receiver, featuring Dolby Atmos and DTS:X surround decoding, with the ability to drive overhead speakers. It is equipped with 9 channel amplification, rated at 110 watts per channel (8 ohm, 20 Hz - 20 kHz, 0.08% 2ch Drive), so you can set up a 7.1.2 or 5.1.4 3D experience without an external amplifier; with an additional amp the set-up can expand to 7.1.4, as the SR6012 features 11.2 channel processing. in simpler surround set-ups two channels of the SR6012's integrated amplification can be assigned to drive speakers in a second audio zone, even playing a different source from that in the main room. The SR6012's futureproof advanced video section is fully compatible with the latest HDMI and HDCP 2.2 specifications on all 8 HDMI inputs. With 4K Ultra HD 60Hz video, 4:4:4 Pure Color sub-sampling, High Dynamic Range (HDR), 21:9 video, 3D, and BT.2020 and Dolby Vision pass-through on every input, the SR6012 is absolutely future-proof. And in addition, HLG (Hybrid Log Gamma) pass-through is also supported for forthcoming HDR broadcasting contents, and eARC (Enhanced Audio Return Channel) will be supported via a firmware update as well. Built-in HEOS wireless multi-room music networking technology means the SR6012 can integrate with other HEOS products to enable you to enjoy your favorite music around your home. Explore, browse, and play your own music library, and access online streaming music service and thousands of internet radio stations using the free HEOS app, while Bluetooth and AirPlay let you stream music directly from any compatible device. [/size][/size] |
Key Features
- 9.2 channel AV Receiver with 110 W per channel (8 ohm, 20 Hz - 20 kHz, 0.08% 2ch Drive)
- 4K/60 Hz full-rate pass-through, 4:4:4 color resolution, HDR, BT.2020 , Dolby Vision and HLG (Hybrid Log Gamma) pass-through
- 8 HDMI inputs (incl. 1 front) with full HDCP 2.2 support; 3 HDMI outputs (inc Zone 2)
- eARC (Enhanced Audio Return Channel) support via firmware update
- Analog to HDMI conversion and SD to HD/4K Upscaling
- Dolby Atmos (up to 7.1.4 with an external 2ch amplifier) and DTS:X:tm:
- Built-in Wi-Fi with 2.4GHz/5GHz dual band support
- Built-in HEOS wireless multi-room audio technology
- AirPlay 2, Bluetooth, TuneIn Internet Radio, Pandora, Spotify, Amazon Prime Music, iHeartRadio, SiriusXM, SoundCloud, Tidal, Napster or Deezer Network Audio Streaming
- Now available – Apple AirPlay 2
- DSD (2.8/5.6MHz), FLAC, ALAC and WAV support
- Audyssey MultEQ XT32, LFC, Sub EQ HT, Dynamic Volume and Dynamic EQ
- Color-coded speaker terminals, Setup Assistant, Marantz 2016 AVR Remote App
- Intelligent ECO mode with off/on/auto setting
- Advanced multiroom options; 11.2-channel processing with pre-outs for all channels; RS232 Control; Crestron Connected
- Control with Alexa voice commands this September.
The SR6012 features identical discrete high-current output power amplifier devices on each of its 9 channels for superb sound with both music and movies. Rated at 110 watts per channel (8 ohm, 20 Hz - 20 kHz, 0.08% 2ch Drive), it has low-impedance drive capability, for excellent speaker control, and is compatible with 4 ohm speakers too. To enjoy immersive 3D sound, you can set up a 7.1.2 or 5.1.4 3D experience without the need of external amplifier, or expand to 7.1.4 with an additional two-channel amp. using the SR6012's 11.2-channel processing. Meanwhile the Eco mode provides energy savings: it features an on-screen Eco meter, and allows the receiver to be used in power-saving mode. It will either reduce the maximum output power or adopt low-power strategies at more modest settings – and all without affecting the SR6012's superb sound quality. |
Dolby Atmos [size] Feel every dimension in Dolby Atmos. Dolby Atmos transports you into the story with moving audio that flows all around you with breathtaking realism. Enjoy a 5.1 or even 7.1 surround sound speaker system and 4 additional overhead speakers or 4 Dolby Atmos elevation speakers (7.1.4 with additional 2 channel amplifier) for the ultimate home theater experience - including Dolby Surround upmixer for legacy content. [/size] | DTS:X [size] DTS:X:tm: immersive audio places sound where it would occur naturally in space, creating a lifelike, multi-dimensional audio experience in the home. The improved immersion and heightened realism draw you into the world of your favorite movies. The included spatial remapping engine, DTS Neural:X:tm:, gives your movie, game and music collections a new lease on life! DTS:X brings the theater home. [/size] |
Amazon Alexa Voice Control [size] Use your voice to stream your favorite music services to this HEOS-enabled device. Ask Alexa to play music from Pandora, Amazon Music and much more. Switch between inputs (Blu-ray, DVD, Media Player, etc.), turn volume up or down, pause, mute and play the next song — all with your voice. To start streaming with Alexa voice commands, open the Alexa app and select “Skills.” Add HEOS Home Entertainment to enable. Then, go to Smart Home in the Alexa app menu and choose Devices and Discover or say “Alexa, discover my devices.” With HEOS Home Entertainment and Alexa, you can stream to this product and any other HEOS-enabled device. Learn More [/size] | Google Assistant Voice Control [size] Ask your Google Home, Google app or other devices with Google Assistant built-in to control content across your listening environment. Start music in the HEOS app, then ask your Google Assistant to control volume, play, pause, skip tracks and more. ‘Works with the Google Assistant’ feature is always improving — further enhancements arrive in 2019. Learn More [/size] |
AirPlay 2 + Apple Siri Voice Control [size] Stream audio from your favorite music services like Apple Music and Spotify or watch videos from services like Youtube and Netflix from any iPhone, iPad, Mac or Apple TV and hear the audio perfectly synced to your speakers Airplay 2 sources. Airplay 2 also supports multi-room audio – wirelessly stream content to multiple AirPlay 2 compatible devices simultaneously with improved audio buffering to ensure smooth audio playback. AirPlay 2 provides control and grouping of compatible audio devices within the Apple Music or Home app. Use Airplay 2 in-app or with your voice via Siri. Learn More [/size] | Josh.ai Smart Home Voice Automation [size] An elevated voice agent for the high-end smart home, Josh.ai offers flexible voice control for nearly any aspect of your day-to-day experience and entertainment environment. Use voice commands to control the thermostat, lights, home appliances, speakers, AVR and more. Josh.ai is installed by custom integrators and accessed through an app on your phone or tablet. Works with iOS and Android devices. Learn More [/size] |
Marantz 2016 AVR Remote [size] Re-designed from the ground up, the Marantz 2016 AVR Remote app gives you unprecedented control over the latest generation of Marantz network AV Receivers, from iOS and Android phones and tablets. Along with many new features, the graphics and user interface have been completely overhauled: control power, volume, input and settings, or switch within the app to the HEOS app to access an incredible range of music content and streaming services, all with full HEOS wireless multi-room control. [/size] | Hi-Res Audio [size] Discover the incredible fidelity of high resolution audio with the SR6012's ability to decode up to 24-bit/192-kHz ALAC, FLAC and WAV lossless files as well as DSD 2.8MHz and 5.6MHz tracks (the audiophile format of SACD). Play hi-res music via the front panel USB port and network sources, and also listen to other popular file types such as MP3. [/size] |
- View the speaker detection results, to check correct installation
- View before and after results of the Audyssey calibration, making it easy to identify room problems
- Edit the Audyssey target curve for each channel pair to suit your tastes
- Adjust the EQ frequency adjustment range for each channel pair
- Switch between 2 high frequency rolloff target curves
- Enable/Disable midrange compensation to make the vocal region brighter or smoother
- Save and load calibration results
Smart TV Connectivity [size] Via the HDMI CEC (consumer electronics control) functionality on some Smart TVs, it's possible to control the SR6012 with the TV's remote handset. With the receiver's "HDMI control" set to ON, set "Smart Menu" receiver control functions and the TV's Smart Menu home screen will provide you direct access to source and surround mode selections, the main setup menu, and Smart Select configuration presets. [/size]
av.online- New Member
- Number of posts : 2
Registration date : 2019-10-23
» Marantz SR4400 6.1 Channel Av Receiver (Used) SOLD
» Marantz SR6007 7.2 Channel Av Receiver (Used) SOLD
» Marantz SR4500 7.1-Channel AV Receiver (Used) SOLD
» Marantz SR7015 9.2-Channel 4K Ultra HD AV Receiver
» Marantz 5.1 channel receiver SR4200 - rm500
