Yamaha CA-1000 Natural Sound Stereo Integrated Amplifier
Item: Yamaha CA-1000 Natural Sound Stereo Integrated Amplifier
Condition: 7.5/10. Item is in excellent working condition and very clean physical condition.
- Extremely heavy and built to last!!
- The amp is crystal clear and provides nice deep bass with crisp highs!
- Enough power for any speakers!
- Very sweet sounding. Delightful mid-range.
- With 2 phono inputs
- Runs on Class AB or Class A, selectable
- Class A (rated at 18 watts per channel) and
- Class AB (rated at 90 watts per channel)
Price: sold
Yamaha CA-1000
September1 9 7 31 9 7 5Plus
From a time when early solid-state amplifiers in Class B ruled - Yamaha got back to basics with Class A.
The CA-1000 is the first of a very long line of very successful, very reliable and very heavy amplifiers which sold like hotcakes until the mid 1980s : japanese high-end-wise, the CA-1000 is the example everybody else quickly followed.
Two-sided circuit boards, low-noise MC preamp, variable loudness control, switchable Class A / Class AB modes are the rarities which very few other japanese makers had put in their top amplifiers in 1973.
The chassis construction and general layout also was to be a school case of how things would be done afterward : phono stage placed right after the terminals, as far away as possible from the power-supply section, huge 270VA transformer, bigga 18.000µF / 80V capacitors (two), 1% tolerance metal film and styrol resistors, 3-stage DC shelving tone controls, and fully differential with current-mirror power stage driver.
The Class A mode puts 2x 15W into 8 Ohm into your ears, and Class AB up to 2x 70W.
The "current steering" circuit allows the output pairs of transistors to remain in Class A for currents up to twice the bias current, with a power supply lowered to ±26V but a bias current increasing to... 0,5A !
In true Yamaha tradition, begun with the CA-1000, the phono stage is very rich with two inputs, one of which has a (back) selector for MC / MM 50KOhm / MM 100kOhm and a front selector for phono 1 / phono 2 and phono MC.
The phono 1 input has a semi-floating ground circuit attached to the back selector - better for MC cartridges ; phono 2 is fixed at 50kOhm and bypasses the additional preamp - better for MM.
The chassis itself is as sturdy as can be, with a difference in color for the wood enclosure : yellow-ish and very clear for the domestic models, warmer and darker for the export versions.
Depending if the recipient market saw the intermediary version (CA-1000 II), the CA-1000 remained available until the launch of the CA-1010 - aka CA-1000 III in Japan.
Like its CA-1000 II, CA-1010 and CA-2010 followers, the CA-1000 needs room to breathe as bias current is high and hot.
Websites:
https://www.ebay.com/itm/YAMAHA-CA-1000-Stereo-Integrated-Amplifier-Natural-Sound-w-Original-Box-/283411266716
http://www.thevintageknob.org/yamaha-CA-1000.html
http://www.audioreview.com/product/amplification/integrated-amplifiers/yamaha/ca-1000.html
https://www.usaudiomart.com/details/649230792-yamaha-ca1000-integrated-amplifier/
Price: sold
Yamaha CA-1000
Websites:
» Yamaha CA-800 Natural Sound Stereo Amplifier(used)
» Yamaha Natural Sound Stereo Pre-Amplifier C-2a
» Yamaha A-420 Natural Sound Stereo Intergrated Amplifier with MM&MC Phono (Used)
» Yamaha Vintage Natural Sound IS-44 Stereo Receiver Amplifier (Sold)
» Yamaha RX-300 Natural Sound Stereo Receiver Amplifier (price reduced)
