Accuphase P-800 Stereo Power Amplifier Made In Japan ( PL )
Accuphase P-800 Stereo Power Amplifier Made In Japan ( PL )Used In Excellent Condition. Now Selling At RM19,500. Free Shipping Within West Malaysia.
A stereo power amplifier designed to achieve both high quality sound and high output, following the development technology of the M-1000.
It consists of the balance system which connected two sets of all the push pull drive unit amplifiers to the bridge, and has raised the performance.
The balance system requires a transmission system dedicated to positive and negative signals, but noise entering from the outside is canceled in principle, and distortion generated by the amplifier is also canceled by the output circuit. Signal transmission is possible.
In order to achieve the same performance as the monaural amplifier, the power supply unit employs a power supply dedicated to the left and right independent.
In addition, with two power supplies that simply halve the power capacity, the power supply impedance rises and becomes disadvantageous compared to the single transformer method, so the P-800 employs a large capacity transformer of 1.5 kVA that can be used for stereo alone. , Have enough room.
Furthermore, the filter capacitor has a large capacity of 82,000μFx4 and a total of 328,000μF.
In the output stage of each unit amplifier, the broadband transistor of collector loss (Pc) 130W is adopted by 7-parallel push pull composition, and it is a total of 28 pieces with two units of one channel. For this reason, the total collector loss has reached 3.6kW.
In addition, with respect to switching distortion at the time of small output generated in the output stage, the operating point is set strictly so that each element of PNP and NPN is not cut off (state that no current flows) by the input signal. .
In addition, the P-800 is equipped with a low-load impedance switch using a low-impedance drive system that utilizes the basic characteristics of transistors, and by switching the supply voltage, consideration is given to supplying large power even at low loads. The Thereby, 1 ohm load and 2 ohm load are also supported, and sufficient drive of low impedance, low efficiency flat speaker and electrostatic speaker is enabled by all load correspondence.
MOS FET equivalent to a non-switching Class-A drive is adopted as the preceding stage which drives the last stage, and it constitutes with cascode push pull. Moreover, the front stage which sends a signal to this MOS FET also has Class-A cascode push pull composition.
This has constituted the stable output stage with few distortions from the small output of a noise area to the large output of a rated output.
The class A cascode differential push-pull system is adopted as an input stage.
A cascode circuit is a circuit used for high-frequency amplification, stable operation over a wide frequency band, good input linearity, and a wide dynamic range.
The analog type large-sized power meter which can directly read the power between -60dB-+ 3dB by logarithmic compression is carried.
There is also a switch for turning off the meter and lighting.
The input terminal carries both balanced input and unbalanced input.
It is equipped with a natural persimmon finished sideboard.
An optimal fan is sold separately and can be set inside the sideboard when set in a place where heat dissipation is poor or when driving at high output for a long time.
www.stylelaser.com.my
Model | Stereo power amplifier | ||||
Continuous average output (20Hz to 20kHz) |
Total harmonic distortion | 0.05% (1Ω to 4Ω load) 0.01% (4Ω to 16Ω load) | ||||
IM distortion | 0.003% | ||||
Frequency characteristic | 20Hz to 20kHz ± 0dB (level control MAX at continuous average output) 0.5Hz to 150kHz +0 -3.0dB (at 1W output, level control MAX) 0.5Hz to 80kHz +0 -3.0dB (at 1W output, level control- (6dB) | ||||
gain | 28.0dB | ||||
Load impedance | Normal Load Imp. Operation: 4Ω to 16Ω Low Load Imp. Operation: 1Ω to 4Ω | ||||
Damping factor | 200 (EIA, 50Hz) | ||||
Input sensitivity |
Input impedance | Unbalanced input: 20kΩ Balanced input: 40kΩ | ||||
S / N (A correction) | 125 dB (input short-circuit, continuous average output) 95 dB (input 1 kΩ, 1 W output) | ||||
Output meter | Logarithmic compression peak display type -60dB to + 3dB and output direct reading scale | ||||
Semiconductor used | Transistor: 158 pieces FET: 20 pieces IC: 15 pieces Diode: 158 pieces | ||||
Power supply | AC100V / 117V / 220V / 240V, 50Hz / 60Hz | ||||
power consumption | 110W + 110W (no input) 550W + 550W (Electrical Appliance and Material Control Law) 740W + 740W (8Ω load rated output) | ||||
External dimensions | Width 481x height 239 (including legs) x depth 489mm (including rear panel legs) | ||||
weight | 47.2kg |
- Number of posts : 1336
» Accuphase Full Set C-280 Preamplifier + P-800 Power Amplifier Made In Japan ( PL ) (Sold Out)
» Japan Made stereo integrated amplifier
» Sony TA-F 450D Digital Stereo Amplifier Made in Japan (SOLD)
» (sold)NAD 2200 PE Japan Made Power Envelope High Current Stereo Power Amplifier
» Accuphase C280L Pre Amplifier Made In Japan ( PL )
