DLS D3 Floorstand Speaker
DLS D3 Floorstand Speaker (1 PAIR)
Good condition
Price: RM950
Original Price: RM4,500
Please call / whatsapp: 0122907032
- Sensitivity. 88 dB/W/1 m
- Frequency range: 48 Hz - 25 kHz
- Nominal impedance: 4 Ohms
- Recommended amplifier power: 20 to 150W recommended
- Type: 2 ways, transmission line
- Loudspeakers: 2 woofers 8 cm in diameter with paper diaphragm, 1 tweeter with a soft dome, 28 mm diameter
- Magnetic shielding: yes
- Bi-wiring: no
- Connection points: no
DLS D3 is a floor-standing loudspeaker designed for home theatre systems and hi-fi applications. The new edition has a cabinet in black satin finish (also available in white satin).
To satisfy our customers needs we have created a unique type of speaker in different colours to match the home environment.
D3 can be bought without the separate coloured side panels, if you prefer. But if you want something extra there are beautifully shaped side panels in five different colours. They are bought as separate accessories. The priority was to achieve ultimate sound quality with deep bass tones from a slim speaker design, just as for the T3 series.
The exceptional performance of this speaker is a result of advanced speaker-design skills and unique driver technology.
D3 uses the same "transmission line" technique as T3, but with a cabinet of MDF instead of aluminium.
The panels are easy to mount or change. Invisible neodymium magnets make the change very easy. The front, covered with black cloth, can also be easily removed.
Both white and black front grilles are included, choose the colour that best matches your interior design.
Good condition
Price: RM950
- Bi-wiring: no
HAC- New Member
- Number of posts : 10
Registration date : 2018-10-23
» fs: floorstand speaker (used)
» DLS-D3-Floorstand Speaker-(Used)
» DLS D3 Floorstand Speaker
» JBL floorstand speaker
» PSB Floorstand Speaker
