Audio Note DAC-Zero (Price Revised)
Selling my used Audio Note DAC-Zero.
The Audio Note DAC Zero is specifically engineered for sonic performance rather than technical specifications. It uses vacuum tube technology, implemented using traditional Audio Note techniques. The DAC takes the transport’s S/PDIF digital output and converts it to analogue. It features an up-to-date 24bit/96kilohertz Delta Sigma D/A converter that enhances ordinary 16-bit CDs, and the astounding 6111WA mini tube in the output stage. The mini tube has advantage of tube sound and the life span of transistor. Users do not have to worry about tube replacement therefore the tube does not require a socket and could directly print on the PCB board. This method also avoid interface signal loss. It is also the only DAC to utilize the Delta Sigma chip with tube.
Output Impedance: Less than 2k ohms
Reference Output: 2.5V RMS
Channel Balance: Less than 0.5dB
Tube Complement: 6111WA Valve Output Stage
Digital System: 24-bit 96kHz Delta sigma converter chip
Voltage: 240 VAC
Frequency: 50 - 60 Hz
Power Consumption: 11 watts
Fuse Ratings: T500mA anti-surge
Dimensions(w x d x h): 22 x 30 x 11 cm
Weight: 5kg
Condition: 8/10 (mint condition)
Color: Silver
Price: Sold...
Kindly contact Khor 019-7711673 via whatsapp or call.
Voltage: 240 VAC
Weight: 5kg
Color: Silver
Price: Sold...
Last edited by khorht on Thu May 07, 2020 3:18 pm; edited 3 times in total (Reason for editing : Sold)
khorht- Regular
- Number of posts : 70
Registration date : 2017-04-10
Re: Audio Note DAC-Zero (Price Revised)
Available...
khorht- Regular
Available...
khorht- Regular
Available...
khorht- Regular
Available...
khorht- Regular
Available...
khorht- Regular
» Audio Note UK DAC-ZERO (Price Revised)
» Audio Analogue Crescendo CD Player (used) price revised
» Purist Audio Design Aqueous XLR Interconnects (Used) Price Revised
» Cambridge Audio Azur 650C CD Player (Used) Price Revised
» Onkyo NR-TX905 Audio Video Receiver (Price Revised)
