Naim Power-Line Mains cable - sold
Naim Power-Line Mains cable for sale
Condition is 9/10 - hardly used.
Length is 1.5m with UK plug.
Complete with manual, packing and metalbox.
Sold
To Naim, a smooth, stable, low-noise supply is critical. It’s absolutely fundamental to performance. That’s why Naim designed the Power-Line mains cable. Its complex, precision-engineered construction has been defined and refined following solid mechanical engineering principles and then confirmed after hundreds of hours of testing in the listening room.
The Power-Line mains plug features a thermoset resin case carrying floating pins that align to provide an enhanced contact area with the socket connections. The stripped cable ends are secured by specially profiled clamp screws and the cable is both decoupled and clamped by an ingenious die-cast component.
The Power-Line cable itself is custom manufactured with 4mm² cross section copper conductors, individual dielectric insulation and a final rubber outer that provides both high levels of inherent mechanical damping, and the correct stiffness to aid dressing on installation.
Completing the Power-Line is an IEC inlet plug that continues many of the decoupling and electrical continuity themes of the mains plug. It features floating contacts, combined decoupling and clamping, double wiper contacts and case eddy current suppression.
Thermoset resin plug cases with floating pins for superior electrical contact
4mm2 copper conductors with individual dielectric insulation
Rubber outer sheath for high levels of inherent mechanical damping
2m length for added flexibility with installations
Sold
Last edited by peterclting on Sat Feb 15, 2020 5:06 pm; edited 3 times in total (Reason for editing : Sold)
- Number of posts : 2486
» Black Rhodium Super Mains 13 AC power line cable
» Naim Powerline mains cable (SOLD)
» Naim Hi-Line 5 Pin to 5 Pin Interconnect Cable SOLD
» SOLD ! NAIM Power Line
» Naim Hi Line Din to RCA Interconnect and Power Line
