(SOLD) Teac TN-180BT Turntable Bluetooth MM Phono PreAmp 3-speed Vinyl Record Player
I just used a few times for testing. This is an open box, approx 2 months old. Everything is clean including the stylus. All photos are the actual item photos (Taken on 24/02/2020).
Price is: Sold
Contact: SEND PM
Everything working and functional.
3-speed Belt-drive turntable supporting 33/45/78 rpm
Built-in Bluetooth transmitter to BT speakers or headphones
Built-in Phono equalizing amplifier and Phono and Line outputs
High-density MDF cabinet for improved resonance reduction
Sleek design in cherry finish
Auto-return and manual arm lifter
Receipt included
All accessories with box included (RCA, adapter, MAT, Manual, etc)
SPECS:
Motor DC Motor
Speed 33 1/3 RPM, 45 RPM, 78 RPM
Wow and Flutter 0.25%
Signal-to-Noise Ratio 64dB or higher (A-weighted, 20kHz LPF)
Platter Plastic
Diameter of Platter 12", 30cm
Tonearm section
Type Static Balance, Straight
Effective Arm Length 7.9", 200mm
Stylus Pressure Range 0 to 5g
Cartridge section
Type MM-type
Output Voltage 2.4mV (±3dB)
Analog Output section
Connectors RCA Pin x 1 pair (Chrome-plated)
Output Voltage
PHONO 2.4mV (±3dB)
LINE 149mV (–16.5dBV)
Bluetooth section
Range Approx. 30ft. / 10 meters
Supported Codec SBC
General
Power AC 100 to 240V, 50/60Hz
Power Consumption < 1.5W (< 0.2W at Standby)
Overall Dimensions
(W x H x D) 16.5" x 4.1" x 14.0"
420 x 105 x 356 mm
Weight Approx. 10.8 lbs. 4.9 kg
Price is: Sold
Contact: SEND PM
Receipt included
SPECS:
Motor DC Motor
Platter Plastic
Tonearm section
Cartridge section
Type MM-type
Output Voltage
PHONO 2.4mV (±3dB)
Bluetooth section
Supported Codec SBC
General
Overall Dimensions
420 x 105 x 356 mm
Last edited by neo_b on Wed Jun 17, 2020 7:53 pm; edited 2 times in total (Reason for editing : location info)
neo_b- New Member
- Number of posts : 3
Registration date : 2020-03-04
neo_b- New Member
» Sanyo Portable Record Player(Turntable) with Radio(without FM) SOLD!
» vinyl record player
» Teac TN-300 turntable with build in phono stage ( new- display )-sold
» Turntable,speaker,amplifier and vinyl record
» Rega RP3 Turntable Record Player (SOLD!)
