Denon AH-C160W Wireless Sport Headphone (New)
AH-C160W
[ltr]
WIRELESS FREEDOM
Sports Headphones can inspire you to greater efforts in your daily run or workout, or simply make the commute more tolerable - and with the combination of a design built for comfort, durability and superb sound, plus the convenience of wire-free Bluetooth connection to your phone or personal music player, the AH-C160W is designed to give you the freedom to move with the music.
The sleek design of the AH-C160W uses unique Earhook technology, developed with a leading hearing aid specialist, to keep the earpieces in place - even during heavy workouts or when running. Three sizes of ring give the best fit for the ears, ensuring pure music playback and excluding noise.[/ltr]
FEATURES
- High-quality 11.5 mm drivers with digital signal processing
- Bluetooth Class 1 connectivity for tangle-free use and reliable connection
- Clear Voice Capture noise reduction for phone calls, plus voice prompts
- Earhook technology and a choice of eartips for comfort and a secure fit
- Tough construction for life on the move
- Sweat and moisture protection for long-term durability
ACCESSORIES
- 1 pair of Comply Foam eartips
- 4 pairs of silicon eartips (XS, S, M, L)
- 3 pairs of rings
- USB charging cable
- Cable Slider
Carrying case with carabiner
Best Sound Performance
The sound of the Denon AH-C160W has been designed and tuned using advanced digital signal processing - to help and inspire you to achieve your fitness goals faster.Durable
The AH-C160W is designed to survive: as well as its durable mechanical structure, even the electronics inside are coated with Nanofics technology, for IPX5/7 class sweat resistance.
Integrated control buttons
Let you easily change volume, skip tracks, take calls. So you stay in control of all that performance without reaching for your device.
Clear talk
The AH-C160W uses Clear Voice Capture, a sophisticated noise reduction system to deliver the clearest voice quality for phone calls - even in the noisiest environments. Also Multilingual Voice Prompts keep you aware of headphone status - such as battery level - so you can concentrate on getting on with your workout!
Comfortable Fit
Along with four sizes of silicon ear tip, the AH-C160W comes with Comply tips made from Memory foam to ensure ultimate comfort in the ear. They're treated with SweatGuard to keep them clean - however hard you exercise!
SPEC:https://usa.denon.com/us/product/portableaudio/inear/ahc160w
All Stock Is New In Box.
Warranty 12 Month.
Rm899
Free Mytery Gift.
Free Postage In Peninsular Malaysia.
Whatapps Mr Jung 0162215648
Last edited by yong zhen jung on Tue Jun 08, 2021 5:59 am; edited 2 times in total
yong zhen jung- Frequent Contributor
- Number of posts : 1092
Registration date : 2018-11-20
» Denon AH-C160W Wireless Sport Headphones
» AKG K-910 - Wireless Headphone - (NEW)
» TDK WR-700 (WIRELESS HEADPHONE)
» AKG K-910 ( Wireless Headphone )
» Wireless Infra Red Headphone (Used)
