Energy TAKE 2 Canada Made Bookshelf monitor Speaker
Price : RM 280
The Energy Take series of speakers are designed for rooms where space is a constraint or you want music to be reproduced without the speakers being too obvious in the room. Each speaker is 6.75″ tall, 4″ wide and 5.25″ deep and will easily sit on the palm of your hand. Within the speaker is a 3.5″ polymer/aluminum woofer and 1″ aluminum dome tweeter.
Frequency response is 80-20KHz with a nominal impedance of 8 ohm and a sensitivity of 89dB. Manufacturer recommends a power amp of 10W to 150W.
On its own, the diminutive speaker throws out a relative large soundstage for its size. A subwoofer is recommended if you are planning to use them as the front stereo speakers but optional if you are using them as surround speakers.
- Number of posts : 2967
Up
» Rogers LS3a High-end audiophile bookshelf monitor speaker (German made)
» Paradigm Monitor 11 v.3 Floorstanding Speaker Made in Canada (PL) - Reserved
» SOLD - ENERGY (Made in Canada) 5.0ch speakers
» ENERGY EPS-100 Canada Made Powered Active Subwoofer
» Special modded Mirage M-490 Hi-Fi audio bookshelf speaker 8" woofer 1" mordaunt short HE tweeter made in canada
