Chord Anthem Reference XLR Audio Interconnect - 1M
Item: Chord Anthem Reference XLR Audio Interconnect - 1M
Condition: 8.5/10. Item in excellent condition.
Price: RM1600 or swap/topup
"Detail, definition, dynamics, timbre, plus outstanding coherence. Everything you need to bring music to life."
The Anthem Reference is a completely new cable design and its Aray conductor configuration brings outstanding dynamics right through the frequency range. Detail and definition is excellent, and there is a coherence that allows you to see, understand and engage with whatever musical performance you are listening to.
Silver-plated conductors are insulated with PTFE, surrounded with an extremely effective dual layer shield and terminated with direct silver-plated VEE 3 RCA plugs.
The design of the Anthem Reference with its Aray conductor set means that it will carry a signal from any component more accurately. Almost regardless of the cost of your components, connecting them with Anthem Reference will show you just how important interconnects can be when it comes to enjoying and becoming immersed in and amazed by your favourite albums.
The Cable The Chord Anthem Reference is another design that has been heavily influenced by the work we have done in developing the ARAY technology that appears on our high end interconnect cables. Heavy gauge, silver-plated oxygen free copper conductors are insulated with PTFE and arranged in a repeating spiral, before being over-extruded with soft PVC to minimise mechanical noise. The shielding comprises of an extremely dense braid in combination with a heavy gauge foil over-wrap. This provides a high degree of interference protection across a very wide frequency range. The shields are protected with a soft vibration damping outer jacket.
The Plugs The Anthem Reference is fitted with Chord's custom VEE 3 RCA plugs. The new design of the ABS outer shell and the unique silver-plating process applied to the contact areas improves signal transfer across a wide frequency range. The signal return surround provides a secure high pressure contact with all types of RCA sockets. The centre pin is insulated with PTFE and the design of the plug and ABS outer shell provides good strain relief, without compressing the cable and compromising performance.
Use it with Like the Chorus, the Anthem Reference's use of the conductor ARAY technology, originally developed for the Chord Sarum, makes for a cable with an extremely accurate signal transfer. The heavier gauge conductors used in the Anthem Reference produce a remarkably detailed and particularly coherent sound. Micro-dynamics are carried extremely accurately making it easy to hear and understand the very subtle rhythmic interplay between musicians. The tri-conductor configuration also makes for excellent definition across a wide frequency range and produces an extremely stable sound stage.
The Cable
The Chord Anthem Reference is another design that has been heavily influenced by the work we have done in developing the ARAY technology that appears on our high end interconnect cables. Heavy gauge, silver-plated oxygen free copper conductors are insulated with PTFE and arranged in a repeating spiral before being over-extruded with a soft PVC to minimise mechanical noise. The shielding comprises of an extremely dense braid in combination with a heavy gauge foil over-wrap. This provides a high degree of interference protection across a very wide frequency range. The shields are protected with a soft vibration damping outer jacket.
The Plugs
The Anthem Reference, like the Chorus Reference, is heavily influenced by our Sarum Tuned ARAY cables. The tri conductor configuration means that we can produce a balanced XLR cable that performs to extremely high standards and benefits from having an extremely effective, fully floating high frequency shield. The silver-plated conductors are connected to the silver-plated pins on the XLR with our own high performance silver solder.
Use it with
Like the Chorus, the Anthem Reference’s use of the conductor ARAY technology originally developed for the Chord Sarum makes for a cable with an extremely accurate signal transfer and the heavier gauge conductors used in the Anthem Reference produce a remarkably detailed and particularly coherent sound. Micro-dynamics are carried extremely accurately making it easy to hear and understand the very subtle rhythmic interplay between musicians. The conductor configuration also makes for excellent definition across a wide frequency range and produces an extremely stable sound stage.
https://www.hifix.co.uk/chord-anthem-reference-xlr-pair
https://www.lifestylestore.com.au/chord-anthem-reference-xlr-audio-interconnect-1m.html
https://www.audioemotion.co.uk/chord-anthem-reference-stereo-xlr-interconnect-5214-p.asp
[size=34]-Chord Anthem Reference XLR Pair[/size]
[*][*]Completely new cable design
[*]Aray conductor configuration brings outstanding dynamics right through the frequency range
[*]Detail and definition is excellent
[*]Silver-plated conductors are insulated with PTFE
[*]Surrounded with an extremely effective dual layer shield and terminated with direct silver-plated VEE 3 RCA plugs
[size=24]IN DEPTH INFO:[/size]
The Cable
The Plugs
Use it with
» Chord Anthem Reference XLR Audio Interconnect - 1M
» The Chord Co 'Anthem' XLR Interconnect (Used)
» The Chord Co Anthem RCA Interconnect - 1m (Used)
