MS HD Power: MS Power S20 V2 Distribution Block with Cable and UK plug
MS HD Power: MS Power S20 V2 Distribution Block with Cable and UK plug Empty MS HD Power: MS Power S20 V2 Distribution Block with Cable and UK plug
Post by raymond88 Fri May 29, 2020 12:37 am
Item:MS HD Power: MS Power S20 V2 Distribution Block with Cable and UK plug
Condition: 8.5/10. Item is in MINT condition. Display set
Price: sold or swap/topup
Retail Price: RM990
https://www.lazada.com.my/products/ms-hd-power-s20-v3-6-way-filtered-uk-mains-block-i437046580-s641362853.html?exlaz=d_1:mm_150050845_51350205_2010350205::12:1032211143!54400014687!!!pla-296303633664!c!296303633664!641362853!135214038&gclid=Cj0KCQjwwr32BRD4ARIsAAJNf_0NchlwVcLg5-9JfDi96BWYt6y-UKOHkgMuf1HPKrkpWBaTSETbN0MaAjwSEALw_wcB
Click here to Whatsapp: http://wasap.my/60123816611
MS HD Power: MS Power S20 V2 Distribution Block with Cable and UK plug Ms112
MS HD Power: MS Power S20 V2 Distribution Block with Cable and UK plug Ms212
MS HD Power: MS Power S20 V2 Distribution Block with Cable and UK plug Ms312
MS HD Power: MS Power S20 V2 Distribution Block with Cable and UK plug Ms412
Features
  • 6 Ways BS-1363 13A Socket with Master ON/OFF Switch
  • PRRT Noise Filtration Network using Selected Components
  • Excellent EMI and RFI Suppression to Improve Audio and Visual Performance
  • 48,000 Amp. Surge Suppression Protect Hi Fi / AV Appliances
  • High Spring Rate Phosphor Bronze Sockets Clips Pass the BS Standard 30,000 times plug IN / OUT test
  • 3.0 µm Pure 925 Silver Plating to All Power Clips
  • 5 mm² Power Transmission Bus Bars with Pure Silver plating on High Current Flow
  • Original 3 Cores 6N OFC Double Screened Extension Cord
  • Moulded-on Type Power Plug with 3.0 µm Pure 925 Silver Plated Pins
  • High Spring Rate Phosphor Bronze Fuse Clamps with 3.0 µm Pure 925 Silver Plating
  • Chassis Made of USA V-0 Grade Nonflammable Materials
  • Fitted with BS-1362 Standards 13A Fuese
  • Full Life-Time Warranty
[th]Number of outlets:[/th][th]Type of outlets available:[/th][th]Length of extension cord:[/th][th]Inlet plug:[/th][th]Fuse:[/th][th]Main Switch:[/th][th]Mains Voltage :[/th][th]Max. Current :[/th][th]Max. Wattage :[/th][th]Dimensions :[/th][th]Net Weight:[/th]
6
UK conform to BS1363
2 Meter conform to VDE standards
UK - conform to BS1363; fused and unswitched
13A BS-1362 Silver Fuse fitted at plug
13A BS-1362 Silver Fuse fitted at strip
Yes. Fitted at strip
200 - 240 VAC / 50~60Hz
13 Amp.
3,000 Watt (230V)
60mm x 402mm x 30mm (W x L x H)
0.8 KG (net)
http://www.mshdpower.com/products_p.html?category=sockets&class=uk&oem=1&xml=s20v2&model=MS-POWER%20S20%20V2
Number of posts : 10041
