Accuphase C-200L + P-300L Pre and Power Amplifier (Used) Price Reduced! SOLD
Accuphase C-200L + P-300L pre/power amplifier need not further introduction. This is the 3rd generation of the renown first audiophile matching pre/power model C-200 + P-300. It has made the name Accuphase so famous and where it started with all.
All buttons & switches are functioning. The power VU meters are working with beautiful warm light in the dark. Both units are in original condition. No deep scratches or dent whatsoever. Consider excellent condition for its age.
The RCA sockets & Speaker terminals at the rear panel still very clean and no sign of oxidation.
I will not describe the sound here as you have to listen to it.
Note: Both units have set to local voltage (240VAC), Made in Japan
C-200L
Frequency response: 1Hz to 500kHz
Gain: 60dB (MM), 24dB (Line)
P-300L
Please refer the link below for Manual/Spec and Reviews.
C-200L
http://www.accuphase.com/cat/c-200len.pdf
https://audio-database.com/Accuphase-kensonic/amp/C-200L-e.html
https://www.hifiengine.com/manual_library/accuphase/c-200l.shtml
http://www.audioreview.com/product/amplification/preamplifiers/accuphase/c-200.html
P-300L
http://www.accuphase.com/cat/p-300len.pdf
https://audio-database.com/Accuphase-kensonic/amp/P-300L-e.html
https://www.hifiengine.com/manual_library/accuphase/p-300l.shtml
http://www.audioreview.com/product/amplification/amplifiers/accuphase/p-300.html
Condition: 8/10
Price: SOLD
SMS or WhatsApp only. Billy 012-2821295
C-200L
Total harmonic distortion: 0.005%
Input sensitivity: 0.05mV (MC), 2mV (MM), 126mV (line)
Signal to noise ratio: 66dB (MC), 85dB (MM), 110dB (line)
Output: 126mV (Line), 2V (Pre Out), 8V (Pre out Max)
Dimensions: 445 x 160 x 373mm
Weight: 13.6kg
P-300L
Power output: 175 watts per channel into 8Ω (stereo), 500 watts into 8Ω (mono)
Total harmonic distortion: 0.01%
Damping factor: 300
Input sensitivity: 1.5V
Signal to noise ratio: 120dB
Speaker load impedance: 2Ω to 16Ω
Semiconductors: 56 x transistors, 12 x FET, 8 x IC, 78 x Diodes
Weight: 23kg
C-200L
P-300L
Condition: 8/10
Price: SOLD
yppan- Frequent Contributor
- Number of posts : 526
» Accuphase Classic C-200L + P-300L Pre/Power Amplifier (Used) SOLD
» Accuphase C-200/P-300 Pre and Power Amplifier (Used) Price Reduced!!! SOLD
» SOLD Cary Audio CAD-300SE Signature Monoblock SET Tube Power Amplifier - Price Reduced
» Accuphase DP-100 / DC-101 SACD transport / DAC (Used) (PRICE REDUCED!)
» (Price reduced)SMSL VMV A1 Power Amplifier
