Herbie Audio Lab tube dampers (new)
I have 2 set ( 1 set consist of 2 pieces of tube damper)
Price RM150 for a set ( consist of 2 pieces of tube damper)
Item in Putrajaya
Whatsapp 0162767272
https://wasap.my/60162767272
Set No 1 :
UltraSonic SS-9: This damper fits small-signal miniature nine-pin tubes 3/4" to 7/8" diameter (19mm to 22mm), including 12AT7/ECC81, 12AU7/ECC82, 12AV7, 12AX7/ECC83, 12AY7, 12AZ7, 12B4, 12BH7, 12BY7, 12BZ7, 12DW7, 12FQ7, 2C51, 396, 396A, 417, 5670, 5751, 5755, 5814, 5842, 5879, 5963, 5965, 6072, 6189, 6201, 6267, 6350, 6385, 6414, 6519P, 6688, 6829, 6922, 6955, 6AN8, 6BL8, 6BQ7, 6BZ7, 6C19P, 6C45, 6CG7, 6DJ8/ECC88, 6EU7, 6FQ7, 6GC7, 6GH8(A), 6GU7, 6GW8, 6H23N, 6H6PI, 6N2, 6N2P, 6N23P, 6N3P, 6N6P, 6S4, 6U8(A), 6V4, 7025, 7044, 7058, 7062, 7119/E182CC, 7199, 7308, 7AU7, 8416, Cca, E80F, ECC40, ECC802S, ECC803/S, E288CC, E88CC, EC86, ECC85, ECC86, ECC90, ECF80, ECL86, EF86, EL821, EL86, EM84, EZ80, M8162, PC88, PCC88, T-6 1/2 bulb.
Set No 2 :
UltraSonic SS-30: This damper fits small-signal straight-sided octal tubes approximately 1-1/8" to 1-1/4" diameter (28mm to 32mm), including 12J5/GT, glass 12SJ7, 12SJ7GT, 12SL7/GT, 12SN7/GT, 5691, 5692, 68HC, 6AH4, 6AU5, 6BL7, 6DN7, 6EA7, 6EM6, 6EM7, 6EW7, straight-sided 6F6G, 6FD7, 6FY7, 6H4, 6H4GT, glass 6J5, 6J8P, 6N8P, 6N9P, 6R7GT (glass T-9 bulb), 6SC7 (glass tube), 6SF5-GT (glass tube), 6SH7, glass 6SJ7, 6SJ7GT, 6SL7, 6SN7, 6SN7GT-series (6SN7GT, 6SN7GTA, 6SN7GTB, 6SN7WGT, 6SN7WGTA), 7N7, C3G, MT8 bulb, PL504.
Virtually all vacuum tubes are prone to distortion caused by microphonic vibrations. To overcome audible distortions, a titanium C-ring holds microphonics-absorbing pads against the vacuum tube bulb. The tube's sound is made more clear and precise, less fuzzy and less harsh. Tonal qualities are rendered more true and natural, subtle passages more distinguishable, from the deepest bass through the highest frequencies.
Item in Putrajaya
Whatsapp 0162767272
Set No 1 :
Set No 2 :
acap- Frequent Contributor
- Number of posts : 152
Registration date : 2009-05-22
» Herbie audio lab (HAL) Ultrasonic tube dampers (used) SOLD
» Audio Bastion Redline Dampers (sold)
» Herbie's Audio Lab UltraSonic Rx-50 tube damper (Used)
» HAL Ultrasonic 30 tube dampers & Promitheusaudio Silver interconnects (Used)
» Herbie Audio and Boston Audio Turntable Mat (SOLD)
