Michell Gyrodec suspension upgrade pylons kits
Solidair pylons suspension upgrade for Michell Gyrodec, Gyro SE and Orbe
These solidair pylons are designed to replace the springs used to suspend the turntable in the spectacular Michell Gyrodec and Orbe.
The standard springs are there to isolate the platter from it’s surroundings, they do this but have a few drawbacks. The spring bounce can be a bit annoying, though you get used to it. The main problem is resonance of the undampened springs, which muddies the sound a little in the higher registers. This tends to blur different instruments and vocals into each other.
What you should expect to hear is a more natural sound with significantly improved separation of instruments and vocals. You should hear fine detail that had been previously unnoticed and distinctly hear each different instrument and vocalist.
They are easy fit and don’t change the look of turntable, as they fit inside the aluminium tubes that hide the standard springs. They simply screw onto the standard Michell adjuster posts (not included in the pack as you will already have them).
Installations & instruction video
https://www.youtube.com/watch?v=Qr4mJ3_7ejM
Locations : Selangor
Contact : 0162730957
Conditions : 8/10 no box
RM460 1set/3pcs
Last edited by 33RPM on Tue Aug 03, 2021 4:12 pm; edited 3 times in total (Reason for editing : update)
33RPM- Frequent Contributor
- Number of posts : 158
Registration date : 2009-02-25
yss7401 likes this post
» Michell Gyrodec upgrade Accessories
» Michell Gyrodec SE
» Michell Gyrodec + SME309 (sold)
» J.A Michell engineering Gyrodec tuentable (Used)SOLD
» Michell gyrodec full version
