IPUK HDD8800X AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking
IPUK HDD8800X AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking Empty IPUK HDD8800X AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking
Post by actsessory Thu Aug 13, 2020 6:52 pm
IPUK HDD8800 AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking
  • Latest NEW upgraded version
  • AV/HiFi enthusiast HDD Caddy for serious playback
  • Solid core OFC linear power supply
  • Even higher quality components and parts
  • CNC integrated single piece aviation-aluminum chassis
  • ASM controller chip solution
  • Support capacity up to 16TB
  • LE version for enthusiast
  • Pro X version (Femto-second Clock)
IPUK HDD8800X AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking X0
IPUK HDD8800X AV/HiFi enthusiast USB3.0 SATA harddisk docking enclosure
LE version of linear power HDD dock, the IPUK HDD8800X, the endless fever goes on…
IPUK HDD8800X AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking O1cn018w2kme1i20tlpoayt_36070834
Built for the enthusiast, this CNC integrated, fever-grade USB hard drive docking is carved out of a single solid piece of aviation aluminum block.
An all-aluminum audiophile/videophile USB hard drive caddy.
Subversion AV system performance of the conventional HDD docking.
IPUK HDD8800X AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking X7
IPUK HDD8800X AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking X4
Constant current power supply output from:
*60W custom solid core OFC transformer
*Fully silver-plated OFC (oxygen free copper) conductors
*American LTC (Linear Technology Corporation) 4-way voltage stabilizer
*EPCOS military grade capacitors
*TCXO Femtosecond clock
*ASM1351 main control
IPUK HDD8800X AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking X9
Designed and built by the LE team which produced and engineered the Oppo UE (Ultimate Edition) version UDP.
*Communication and electricity separation
*Maximum audio/video data transfer efficiency + accuracy
IPUK HDD8800X AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking X8
*Precision CNC milling from solid aluminum block
IPUK HDD8800X AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking X1-copy
*SATA6 interface
*Compatible with 2.5″, 3.5″ hard drive/SSD HDD
It provides a HDD enclosure function and performance, while improving data reading/writing stability, the pursuit of excellence in data retrieval quality.
IPUK HDD8800X AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking X6
4.8kg all-aluminum chassis and isolation damping silicone feet effectively reduces vibration from the hard drive operation.
IPUK HDD8800X AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking Hdd8800a
ASM1351 Controller chip is equipped with clock separation technology to remove jitter interference and provides stable and accurate data retrieval.
Supports HDD capacity up to 16TB, tested.
IPUK HDD8800X AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking Hdd8800d
The result is obviously improved color saturation, cleaner picture, quieter background and better contrast in video, and enhanced audio separation and immersion, thicker sound.
**Pro X, Femto Clock version**
IPUK HDD8800X AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking X3
WHAT IS FEMTO-SECOND CLOCK?
It’s a crystal (oscillator) clock of 500 times higher accuracy than the standard one out there.
Every femto-second clock used, is of military grade, each of every single clock has a serial number and individual test data report of its own.
This ensures product consistency, most stable and maximum effect.
The data conversion requires high precision, thus the higher the accuracy, lesser jitter, the more complete information, followed with much better the images and sound output.
Whether you are a music or movie enthusiast, you deserve it, better visual and purer sound quality.
Dimension: W138 x D255 x H70 mm
Weights : 4.8kg
Fine, transparent and solid 3D-like images with vivid color and high contrast.
Sonically full and thick yet powerful, rich in details.
A decent USB cable can further improve!  – CLICK HERE–>  IPUK HDD8800X AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking Wireworld_starlight8usb3_square04
Price:  RM4,080
1 Year Local Warranty
Location at Subang Jaya SS14
**Credit Card accepted.
Contact 0126116917
actsessory
Number of posts : 2474
http://www.actsessory.com
IPUK HDD8800X AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking Empty Re: IPUK HDD8800X AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking
Post by actsessory Tue Nov 10, 2020 10:09 pm
IPUK HDD8800 PRO AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking
*CNC integrated single piece aviation-aluminum chassis
*LE version for enthusiast
*Linear power supply
*Pro version (Femto-second Clock)
IPUK combo in a pre-post HT system of Yamaha AV Pre and all the Primare power amps, Oppo 205, JVC DiLA Proj..
IPUK UHD8581, PRO version, of LE's team dual femto-second clock mod, separately for USB/Network inputs and HDMI outputs, for most accurate, pure data transmission and improved audio video quality.
Space saving, an audiophile, videophile reference grade 4K UHD media player, gathered all the every best mods from LE team, the official Oppo UHD modder, that's IPUK UHD8581
You've just gotta check it out - [url=https://actsessory.com/2020/08/15/ipuk-uhd8581-reference-4k-ultra-hd-hdr-media-player/][You must be registered and logged in to see this link.]
IPUK HDD8800X AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking Hdd88010
IPUK HDD8800X AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking Hdd88011
actsessory
Post by actsessory Tue Dec 20, 2022 10:06 pm
IPUK HDD8800X all-aluminum AV-phile/HiFi grade USB3.0 SATA Harddisk docking of fully upgraded femtoclock circuitry, linear power supply and main circuitry.
IPUK HDD8800X AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking Ek310
*Precision CNC milling from solid aluminum block.
*60W custom solid core OFC toroidal transformer
*Fully silver-plated OFC (oxygen free copper) wires
*18K gold-plated USB connector
*SATA6 interface
IPUK HDD8800X AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking Ek710
*Compatible with 2.5", 3.5" hard drive/SSD HDD
**Subversion AV system performance of the conventional HDD docking.
**Communication and electricity separation
**Maximum audio/video data transfer efficiency + accuracy
IPUK HDD8800X AV/HiFi Enthusiast USB3.0 SATA Harddisk Docking Ek610
More info @ [You must be registered and logged in to see this link.]
actsessory
