Marantz SACD 30n Network SACD Player
Marantz SACD 30n Network SACD Player Brand New. Now Selling At RM14,999. Free Shipping Within West Malaysia.
Key Features
SACD 30n
Features
AirPlay 2 Yes
Amazon Prime Music / Pandora Yes / Yes
Asynchronous Mode Rear USB-B Yes
Bit-perfect Transmission Yes
CD Compatibility: CD / CD-R/RW / SA-CD / WMA / MP3 / AAC Yes / Yes / Yes / Yes / Yes / No
Customised Components Yes
DAC Operation Mode: USB-B / Coax / Optical Yes / Yes / Yes / Yes
Data Disc Compatibility: DSD / WAV / ALAC Yes / Yes / Yes / Yes
Digital Out Off / Audio EX Mode Yes / No
Extra Metal Plate for Chassis Strengthing Yes (1.5mm)
HDAM Version HDAM+HDAM SA3
Headphone: Standard / Buffer / Current feedback No / No / Yes (HDAM SA2)
HEOS Multiroom and Streaming Yes
High Grade Audio Components Yes
Jitter Reducer Yes
Network Audio Streaming Yes
Power Transformer: Toroidal / El Yes / No
Roon Tested Yes
Signal Isolator for DAC Mode operation Yes
Spotify Connect / Tidal / Deezer/ Others Yes / Yes / Yes / Yes
Symmetric Circuit Layout Yes
USB Input for Memory Stick Yes
USB-B DSD Audio Streaming (DoP): DSD2.8 / DSD5.6 / DSD11.2 Yes / Yes / Yes
Voice Control - Google Assist / Apple Siri Yes / Yes
Voice Control - Works with Amazon Alexa Yes
General
Auto Power off Yes
Available Colors: Gold / Silver / Black / Silver-Gold No / No / Yes / Yes
Carton Maximum Dimensions (W x D x H) in mm 534 x 522 x 255
Carton Weight (inc. product) in kg 16.2
Detachable Power Cable Yes
Maximum Dimensions (W x H x D) in mm 443 x 424 x 130
Metal Front Panel Yes
Power Consumption in W 48
Remote Control RC002PMND
Standby Consumption in W 0.4
Weight in kg 13.5
Inputs/Outputs
Analogue Out (Cinch) 1
D-Bus Yes
Digital Coaxial In / Out 2 / 1
Digital Optical In / Out 1 / 1
Ethernet Port Yes
Flasher Input Yes
Gold Plated Cinch Yes
Headphone Out Yes
Headphone Volume Control Yes
IP control Yes
RS232 Yes
Sample Rate digital In 192 kHz / 24-bit
USB Audio (front) Yes (rear)
USB type B Input for PC (rear) Sample Rate USB Type B In Yes up to DSD11.2
Variable Out (Cinch) 1
Network
App Control AMP/CD via Network Player Yes
Bluetooth On / Off Mode Yes
DSD Audio Streaming up to DSD11.2 by Update
Gapless Playback Yes (FLAC, WAV, DSD)
Lossless Formats: DSD / FLAC HD 192/24 / ALAC 96/24 / WAV 192/24 Yes / Yes / Yes / Yes
Lossy Formats MP3 / WMA / AAC Yes / Yes / Yes
Remote APP: iDevice / Android Yes / Yes
Wi-Fi On / Off Mode Yes
Others
Display: Dimmer / Off Yes / Yes
Marantz Musical Mastering Yes
Marantz Musical Mastering Conversion Yes
Marantz Musical Mastering Stream Yes
Selectable Filter: CD / SA-CD / DAC-Mode Yes / No / Yes (PCM Only)
Separated Rectifier Circuit for Analogue and Digital Circuitry Yes
Playback
Program Play (CD / SA-CD) 25 / No
Random Play Yes
Repeat Yes
D/A Conversion MMM
DAC IC MMM
Digital Filter MMM
Dynamic Range 98 dB
Dynamic Range (SA) 109dB
Frequency Response 2 Hz - 20 kHz
Frequency Response (Cust.) 2 Hz - 20 kHz
Headphone Amp HDAM SA3
Low Pass Filter stage HDAM
Mechanism SACDM-3L
Noise Shaper MMM
Output buffer HDAM SA3
Signal to Noise Ratio 104dB
Signal to Noise Ratio (SA) 112dB
Total Harmonic Distortion 0,000015
Total Harmonic Distortion (SA) 0.0008%
SACD 30n
The most musical digital source player for CDs, SACDs, and high-resolution files, plus multiple streaming services. Delivered through Marantz Musical Mastering processing and a crystal-clear pre-amplifier.Key Features
- Tuned with passion:Hundreds of hours of careful Sound Master tuning ensures the exquisite detail and musicality Marantz always delivers.
- Designed for real listening:Its low-noise pre-amplifier and dedicated headphone amplifier promise the Marantz sound any way you listen.
- HEOS Built-in:Enjoy music from Spotify, Amazon HD, Pandora, TIDAL, and more, or your local collection.
- Pair with the MODEL 30 amplifier:Exquisitely designed and precisely tuned to pair with the Marantz MODEL 30 – for your new reference system
The complete digital music player
SACD 30n is built to meet all the requirements of the modern audiophile who wants to combine a large digital music collection with the leading online music services.The most musical, accurate, detailed sound
SACD 30n is built on its own discrete circuit board, the Hyper-Dynamic Amplifier Module, or HDAM.Exquisite sound tuning
SACD 30n continues the renowned heritage of exquisite Marantz components.Transport Mechanism: A history of excellence
Marantz launched its first CD player – the original CD-63 – in 1982. We’ve continued to innovate ever since.Legacy system connectivity
SACD 30n integrates the Marantz Musical Mastering digital-to-analog converter.More than 65 years of audiophile heritage
Founded in 1953, Marantz has a long and rich history of designing audio components embraced by music lovers and critical listeners around the world.Independent variable output terminal
SACD 30n provides a separate low noise variable level connection output to active speakers, or a power amplifier direct input, letting you use it as a multi-source digital player/pre-amplifier. Volume can be controlled from the remote handset or via apps. When not in use, the preamp power supply is turned off to avoid any noise or interference.Interested please feel free to contact:
SACD 30n
Features
AirPlay 2 Yes
Jitter Reducer Yes
Roon Tested Yes
General
Auto Power off Yes
Weight in kg 13.5
Inputs/Outputs
D-Bus Yes
Ethernet Port Yes
Flasher Input Yes
Headphone Out Yes
IP control Yes
RS232 Yes
Network
Others
Playback
Random Play Yes
Repeat Yes
D/A Conversion MMM
DAC IC MMM
Digital Filter MMM
Dynamic Range 98 dB
Mechanism SACDM-3L
Noise Shaper MMM
- Number of posts : 1318
» Marantz SACD 30N Network SACD CD Player (Used)
» Marantz UD7007 super audio cd player/blu-ray player/sacd player/blu ray player/blu-ray player
» Arcam CDS50 CD/SACD Network Player (Sold)
» WTB : Marantz SA7S1 CD/SACD player or any similar quality player (CLOSED)
» Marantz SA-10 Sacd player (used)
