Elekit TU8200 Integrated Amplifier (Reduced)
Elekit TU8200 Used / Upgraded components
Condition : very good (no scratches)
Price :
Contact : 016 2010734 (whatsapp)
- Tubes : 6L6GC x 2, 12BH7 x 2
- Circuit automatically adjusts bias for the optimal operation of each tube
- 3 amplification modes (triode, pentode and ultra-linear) can be selected using PCB jumpers - Ultra linear (8W + 8W) / Triode (4W + 4W) / Pentode (8.2W + 8.2W)
- FET ripple filter on board for power B for both left and right channels
- Overcurrent protection
- High quality PCB with 70um copper traces (double regular thickness)
- Audio Inputs 1 - 2x RCA, Input 2: 2 x RCA / 3.5mm jack
- Audio Outputs - Speaker impedance selector switch - 8-16Ω / 4-6.3Ω Headphone jack at front
- parts upgraded
- For details of parts upgraded please refer to link below
https://www.diyaudio.com/forums/elekit/331769-elekit-tu-8200dx.html
Component(s) | Original Value | New Value | Comment |
C22 | 180μF/400V | 270-330μF/400V | Significanty less hum on headphone output. Max length = 36mm |
C23,C24 | 10μF/400V | 22μF/400V | More delay to B+ voltage, protecting tubes after switching on the amp. Max length = 36mm |
C7,C8,C11,C12 | 10μF/400V | 15μF/400V | Optional - gives a bit more room. Max length = 20mm |
C31,C32 | 3300μF/10V | 10000μF/10V | Higher and better filtered DC heater voltage. Max length = 36mm |
R64 | 0.47 Ohm | Short (0 Ohm) | Cut off a pin of a resistor, bend it twice |
D7 | DB107 | DB207 | Lower forward voltage drop. Required for driver update. |
C34,C35 | 220μF/16V | 220μF/16V | Optional - gives better high frequency filtering of bias reference |
C13,C14 | 220μF/16V | 470μF/16V | The low ESR is very important |
C33 | 220μF/16V | 330-470μF/16V | Better low frequency filtering of bias reference |
bakmei- New Member
- Number of posts : 19
Registration date : 2012-10-23
Source(s): Chord Hugo dac, Melco NA1 server
Amplification: LTA Micro ZOTL pre, StereoCoffee LDR pre, Graaf GM20 power amp, Mingda 2A3/300B integrated
Speakers: Cube Audio F10 Neuphar, magnepan 1.7
Re: Elekit TU8200 Integrated Amplifier (Reduced)
Price reduced
bakmei- New Member
» Elekit TU8200 Tube Amp with additional upgrades (sold)
» Elekit TU8200 with Lundahl Output Trans upgraded
» Rotel Integrated Amplifier RA 971 MK II-(Price Reduced)
» Elekit KT88 tube amplifier(used)
» Sansui A-60 Stereo Integrated Amplifier (Sold)
