Solid Tech Accessories: Turntable Shelf Large, Feet Of Silence, Discs of Silence
Solid Tech Accessories: Turntable Shelf Large, Feet Of Silence, Discs of Silence  Empty Solid Tech Accessories: Turntable Shelf Large, Feet Of Silence, Discs of Silence
Post by raymond88 Thu Jan 14, 2021 12:05 am
Item: Solid Tech Rack Of Silence Turntable Shelf Large - Black  w/ Spirit Level
Condition: 9/10. Item is in like new condition. Comes with original packaging
Price: RM850 or swap/topup
Solid Tech Accessories: Turntable Shelf Large, Feet Of Silence, Discs of Silence  Tt110
Solid Tech Accessories: Turntable Shelf Large, Feet Of Silence, Discs of Silence  Tt210
Solid Tech Accessories: Turntable Shelf Large, Feet Of Silence, Discs of Silence  Tt310
Solid Tech Accessories: Turntable Shelf Large, Feet Of Silence, Discs of Silence  Solidt16
Solid Tech Accessories: Turntable Shelf Large, Feet Of Silence, Discs of Silence  Solidt17
DESCRIPTION
Turntable shelf for the Rack of Silence.
Manufactured from MDF and painted in black or white texture paint, with flush mounted Spirit Level
Allows for placement of a turntable with separate motor and plinth.
Dimension is 695 x 520 x 22mm and weight is 6 kg.
When supported only in the corners the max recommended load is 50kg. However if the top most ROS-Shelf is raised and Apparatus-Supports are placed between the ROS-Shelf and the TT-Shelf the max recommended load of the supported shelf can be added.
https://www.solid-tech.net/product/rack-silence-turntable-shelf-large/
https://sightandsoundgallery.com/products/solid-tech-hybrid-turntable-shelf
Item: Solid Tech Feet Of Silence (Set of 4)
Condition: New set, unused with box.
Price: RM1900 RM1500 or swap/topup
New Retail Price: USD650
https://upscaleaudio.com/products/solid-tech-feet-of-silence
Solid Tech Accessories: Turntable Shelf Large, Feet Of Silence, Discs of Silence  Solidt10
https://www.audioadvisor.com/prodinfo.asp?number=SOFESI
https://www.solid-tech.net/feet-of-silence/
Item: Solid Tech Discs of Silence Set of 4
Condition: 9/10. Item is in like new condition. Comes with original box.
Click here to Whatsapp:
http://wasap.my/60123816611
Solid Tech Accessories: Turntable Shelf Large, Feet Of Silence, Discs of Silence  Solidd10
http://audiofi.net/2015/01/solid-tech-disc-of-silence-spring-fling/
https://www.thecableco.com/disc-of-silence-set-of-4.html
https://www.solid-tech.net/disc-of-silence/
https://krispyaudio.com.au/products/solid-tech-disc-of-silence.html
https://www.audioadvisor.com/prodinfo.asp?number=SODISI
Number of posts : 10077
Solid Tech Accessories: Turntable Shelf Large, Feet Of Silence, Discs of Silence  Empty Re: Solid Tech Accessories: Turntable Shelf Large, Feet Of Silence, Discs of Silence
Post by raymond88 Thu Jan 21, 2021 10:02 pm
Post by raymond88 Fri Jan 29, 2021 11:43 am
