YAQIN MC-100B 60WPC KT88 Class A Tube Integrated Amplifier
Features
1.User-selected amplifier modes, UT (Ultra linear) mode provides greater output power and TR (Triode) mode does smooth and rich sound.
2.Class A push-pull power amplifier to reduce distortion;
3.User-selected pure post-stage and integrated modes;
4.Utilizes the audiophile capacitors and high quality metal precision resistors dedicated for audio frequency;
5.Output transformers manufactured with Japanese silicon steel sheet and oxygen-free enameled copper and high quality lacquer, which offer a wide dynamic range at full rated output;
6.Independent power supply for each channel.
7.Beautiful heavy duty chassis (stainless steel top, steel buttom) and aluminum panel and bezels;
8.Provides user adjustable bias, test points and tool to refine bias of the output tubes.
Parameters:
Tubes: KT88-98 × 4 (Output Tubes)
6N8P × 4 (Drivers and Cathode followers)
12AX7B × 2 (Voltage amplifiers)
Maximum Output:
30W per channel (8Ω and Triode Mode)
60W per channel (8Ω and Ultra linear Mode)
Output Jacks: Two channels with two groups gold plated jacks
Output Impedance: 4Ω and 8Ω
Input Jacks: Gold plated isolated RCA jacks, 4 groups (CD, DVD, Tape, and Tuner) on rear, and 1 group on front as the input of post-stage mode
Input Sensitivity:
0.25V in integrated mode (CD, DVD, and Tuner)
0.6V in pure post-stage mode (Front input connectors)
Distortion of Harmonic Wave: ≤1.5%
Frequency Response: 5Hz ~ 80KHz (-2dB
Signal-to-Noise Ratio: 90dB (A weight)
Supply Voltage: AC 220V, 60Hz
Power Consumption: 250W
Net Weight: 23kg
Shipping Weight: 30kg
Shipping Dimension: 60cm x 52cm x 36cm
18 months warranty
New in box
Price: RM3,999
- Number of posts : 1404
» Yaqin MS-500B Tube Class A Single-Ended Hifi Integrated Amplifier
» YAQIN MC-13S Class A Vacuum Tube Push-Pull Hifi Integrated Amplifier
» Yaqin MS-650B 845 Tube Class A Single-End Integrated Amplifier + FREE GIFT
» Yaqin MC-100B Integrated Tube Amp (Used)SOLD
» Yaqin MS-6V6 Class A Vacuum Tube Integrated Headphone Amplifier
