Inakustik Reference LS-4004 Air Spade/BFA Speaker Cable (3m)
Description
With the Referenz LS-4004 speaker cable, we continue the incredible story of their Air Helix technology: To achieve perfect air insulation, the new cable uses no less than 16 Cross Link Super Speed waveguides (rather than eight as with the Referenz Air Helix LS 2404). Obviously, the individual conductors themselves play a key role, too. With the LS-4004, too, these are made of 24 high-purity copper wires, each with a razor-thin lacquer coating for extra insulation and braided around a PE core. This design considerably increases stability inside the waveguide by effectively preventing the formation of eddy currents. (These are caused by the very high currents transmitted on the speaker cables – actually the highest ones within the entire audio path.)Freatures :
- Rhodium-coated contacts
- The PE network jacket against micro-vibrations
- Angle of plugs adjustable
- 16 fold Cross Link Super Speed waveguides
- 16 x 1,2mm² copper wires; insulated with lacquer
- Wires upon PE core
AIR HELIX STRUCTURE
In addition, a new clip capable of carrying the increased load of the updated design had to be constructed. This clip not only must bear the surplus weight of the conductors but also needs to ensure flexibility throughout the cable structure. Just like its smaller predecessor, the new clip suspends the helical conductor arrangement freely in the air while keeping the individual conductors at an exact distance throughout the cable. The clips are meticulously assembled by hand at the on-site factory and then threaded into the Cross Link Super Speed waveguide. Finally, the resulting Air Helix receives a highly protective PE network jacket.AND WHAT ABOUT THE AUDIO QUALITY?
Basically, adding conductor material leads to an increase of the controlled currency throughput. The result is a highly dynamic, incredibly open sound with unprecedented detail.New in box
Price: RM39,900
- Number of posts : 1404
» Inakustik Reference LS-1204 Air Spade Speaker Cable (3meter)
» Inakustik Reference LS-4004 Air Pure Silver Speaker Cable (3m)
» Inakustik Reference LS-804 Air Spade Speaker Cable (3meter)
» Inakustik Reference LS-204 Micro Air Spade Speaker Cable (3meter)
» Inakustik Reference LS-204 Micro Air XL Spade Speaker Cable (3 Meters)
