Schiit Lyr 2 - Tube Headphone amp
Specifications (copied straight from the Schiit website)
Frequency Response: 20Hz-20Khz, -0.1db, 2Hz-500KHz, -3dB
Maximum Power, 32 ohms: 6.0W RMS per channel
Maximum Power, 50 ohms: 4.0W RMS per channel
Maximum Power, 300 ohms: 660mW RMS per channel
Maximum Power, 600 ohms: 330mW RMS per channel
THD: < 0.01%, 20Hz-20KHz, at 1V RMS, gain = 8 mode (worst case, stock tubes)
IMD: < 0.01%, CCIF at 1V RMS, gain = 8 mode (worst case, stock tubes)
SNR: > 98db, unweighted, referenced to 1V RMS, in gain = 1 mode
Crosstalk: < -65dB, 20 Hz-20KHz
Output Impedance: 0.7 ohms (high gain), 0.3 ohms (low gain)
Gain: 7 (16.9db) or 1 (0 db), via rear switch
Topology: Dynamically Adaptive Class A/AB, noninverting, hybrid tube/MOSFET, single voltage gain stage, DC-coupled input and output
Protection: standard muting relay for delayed turn-on and fast turn-off
Power Supply: Two internal power transformers, five internal regulated rails, with over 30,000uf of filter capacitance
Power Consumption: 30W
Size: 9 x 6 x 2.25”
Weight: 6 lbs
Perfect condition condition
Great for tube rolling (ECC88)
COD KLCC or Bukit Tungku
Price:RM1'300
contact: Paul o!2 6o9 98!2
Size: 9 x 6 x 2.25”
Weight: 6 lbs
Price:RM1'300
esteboune- Club Member
- Number of posts : 27
Registration date : 2011-04-11
Re: Schiit Lyr 2 - Tube Headphone amp
Still available!
» Schiit Mjolnir 2 Headphone Tube Amplifier
» Sold - Schiit LYR Hybrid Headphone Amp. (Used)
» Schiit Saga+ Tube Pre-amp (Made in USA)
» Schiit Asgard 2 headphone amplifer / preamplifier
» Schiit Asgard headphone amplifier (Sold)
