AudioControl Savoy G3 Multi Channel Power Amp (7 Channel x 203w ) with Box
AudioControl seven-channel Savoy G3. Designed to stimulate enthusiasts both audibly and visually, the Savoy G3 combines AudioControl’s legendary audio performance with its leading contemporary design. The high power levels of the Savoy G3 allow it to be an active participant in even the most demanding theater systems.
The Savoy G3 is a seven-channel amplifier that incorporates a unique and highly efficient AudioControl Class H with Class AB design. This allows it to produce over 200 watts into each channel, all channels driven, at an 8-ohm load, or almost 1500 watts total audio output. Designed as a matching companion to AudioControl’s new Maestro M9 theater pre-amp processor, the Savoy G3 changes the experience in the home for all movie lovers.
The Class-H design topology of the Savoy G3 provides increased efficiency and bullet-proof reliability, while reducing heat and unnecessary power dissipation. The Savoy G3 incorporates AudioControl’s LightDrive Anti-Clipping Protection Circuit, which safely eliminates any possibility of speaker-damaging clipping and distortion, even in extreme conditions. Audio enthusiasts can enjoy their audio systems at even the most aggressive levels.
In addition to pristine audio performance, the Savoy G3 sports desirable user features like balanced XLR and unbalanced RCA inputs, Remote Power Control triggers and audiophile grade, five-way binding posts to guarantee the optimum connection of speaker level signals.
Review : https://www.audiocontrol.com/downloads/home/current/savoy-g3/wsr-hightlights-m3-g3.pdf
Actual image: (call more pictures if interested
Condition : 8.0/10 with original box like new
Price : RM8,800 8600
Warranty : 3 months
Please call or whatsapp if interested : 012-7273382
inputs
- Inputs: 7 RCA Unbalanced, 7 XLR Balanced
- Input Sensitivity: 1.42 Vrms for full output
- Input Impedance: 22kΩ
outputs
- Amplifier Channels: 7
- Power Output (8Ω): 203W per channel
- Minimum Speaker Load: 4Ω
- performance
- Damping Factor: >450
- Total Harmonic Distortion: 0.08% (203 watts @ 8 ohms 20-20K)
- Signal to Noise: >110dB, A-wtd ref Full Output
- Frequency Response: 10Hz-20kHz ±3dB
control
- Remote Power Trigger: +12 VDC or Dry Contact Closure
- weights & dimensions
- Dimensions: 17”W x 16.5”D x 7”H (4U)
- Weight: 55.0lbs (24.9kg)
Price : RM
Warranty : 3 months
Last edited by khthen on Sun May 23, 2021 10:36 am; edited 3 times in total (Reason for editing : change of warranty)
khthen- Frequent Contributor
- Number of posts : 190
Registration date : 2013-09-24
» AudioControl Savoy G3 Multi Channel Power Amp ( 7 Channel x 200w ) ( sold)
» AudioControl seven-channel 200W per Channel Savoy G3
» Aragon 8008 X5 multi channel power amp
» WTS Proceed M5 multi channel power amplifler
» Meridian 558 Multi Channel Power Amp (used)
