SOLD XiangSheng DAC-05B II 2x AK4497EQ XMOS Balanced DSD 512 Tube DAC with Bluetooth 5.0
Item: XiangSheng DAC-05B II 2x AK4497EQ XMOS Balanced DSD 512 Tube DAC with Bluetooth 5.0
Condition: 8.5/10. Item is in like new condition. No dents or scratches.
Price: SOLD or swap/topup
Retail Price: RM2300
Click here to Whatsapp:
http://wasap.my/60123816611
https://hifi-exquis.com/ak4xxx-decoder/701-xiangsheng-dac-05b-ii-2x-ak4497eq-xmos-balanced-dsd-512-tube-dac.html
Specifications and Parameters:
- Simple dimensions: width 330mm, depth 220mm, height 70mm (except button, machine feet, connector size)
- Frequency response: 20Hz-35KHz
- SNR: General port output: 110dB (hifi exquisite)
- Harmonic distortion: general port output: <0.001%
- Support format:
- DSD-DOP, Native DSD, (only supported on Windows PC)
- PCM (wav, wma, APE, Flac, Mp3, etc.)
- Support sampling: (hifi exquisite)
- All of them support 24bit, 192khz, (hifi exquisite)
- USB input for PCM: up to 32bit 384 khz, or 32bit 192 khz, for DSD 64/28/256/512
- SPDIF (coaxial / optical) support at 24bit 192khz, DSD-Dop64
- Output level: balanced 9V output, Standard 2V output
- Dynamic range: balanced output greater than 120dB, unbalanced output greater than 110d
- Output impedance: 600 ohms
- Outputs:
1 Standard analog RCA group output with op-amp
1 RCA group Analog tube output with op-amp and also vacuum tube
Coaxial output: only works with USB input box - Net Weight: 2.6Kg, (hifi exquisite)
- Packing gross size weight: about 5.6Kg (hifi exquisite)
- Input voltage: 110v-240v 60 / 50Hz for all customer countries
Features:
- In order to provide better bluetooth connection, use CSR8675 APTX-HD 5.0 Bluetooth module(with option)
- Best outdoor sound card from Xiangsheng, can compare with all the most expensive hi-fi sound card
- Use the best double toroidal transformers, to ensure the sufficient amount of current
- Driver uses certified original Thesycon reader
- DSD direct decoder up to 252, no DSD switch noise
- UsetheOwest Throw Receiver AK4118 Chip
- All inputs use IIS transmission, (hifi exquisite)
- USB receive use 32bit / 384K XMOS-Xu208 chip, which is asynchronous working, it can effectively reduce jitter values.Double speed than u8 kernel and support more system
- Support Mac IOS system equipment like phone or computer, support all seires windows system, support linux,
- 2x LME49720NA、2x 2604AU op-amp
- Decoder part use 2x AK4497EQ, each chip for one channel in mono mode, AK4495SEQ chip is powered with 7v voltage, it has more dynamics and sound level (hifi exquisite)
- AK4495SEQ already have I / V function, so no need for i / V op-amp
- Dual effect analog output: Standard with op-amp output, Tube buffer with Russian tube 6H3n
- Coaxial output for usb input box
- 5 inputs: ISO-USB, PC-USB, RCA Coaxial, BNC Coaxial, optical
- Use top DALE and TKD resistors from USA and Japan
- Use all high-end audio capacitors (exquisite hifi)
- Use all single or double teflon plated wires inside
- XLR output + - have 9v, (+ 0) or (-0) have 4.5v, RCA output have 2v
» HiFi Set Tube Amp, Full Range Speaker and DAC Tube Output & AK4497EQ Output (Sold)
» Xiangsheng DA-03A USB DAC tube headphone amp HiFi with Remote Control SOLD
» SOLD Tube preamp XiangSheng 728A with bass/treble/balance adjustment (black)
» XiangSheng 728A Tube Pre-amplifier (Black)
» Neoteck Bluetooth amp and FX AUDIO Tube 01 preamp (SOLD)
