SVS PB-1000 Pro Subwoofer
*SVS latest series
*325 watts RMS (820+w Peak Dynamic)
*SVS 12″ high-excursion driver
*Dual Ported Cabinet
*Standard / Sealed mode selectable
*Sledge amplifier STA-325D, fully discrete MOSFET output
*Subterranean low frequency extension of 17Hz – 260Hz
*3-Years Warranty
Room-shaking output well below the threshold of audibility, with pinpoint control and accuracy, the PB-1000 Pro obliterates performance expectations for subwoofers anywhere near the price.
PB-1000 Pro is optimized with a new dual-port cabinet design for effortless bass with vanishingly low distortion
**PB-1000 Pro features two port tuning modes, each with individual response curves to achieve the most accurate in-room frequency response possible whether in sealed or standard mode.
Harnessing the massive power while ensuring unerring control and room-energizing bass response is a 50 MHz Analog Devices Audio DSP.
PB-1000 Pro also features the SVS subwoofer smartphone app for convenient control of volume, DSP functions, custom presets and more.
Protective non-resonant extra-thick ABS fabric mesh grill
All-new 12-inch high-excursion driver with dual high-grade ferrite magnets and FEA-optimized internal motor architecture for extreme excursion and massive, pristine output.
Dual ferrite magnet motor assembly weighing over 15 lbs generates massive amounts of magnetics to produce extreme driver excursion without losing control.
Lightweight and rigid aluminum vented cone with composite fiber dustcap creates room-energizing SPLs while maintaining control even at the highest drive levels.
Long-throw parabolic surround using proprietary injection molding allows extreme excursion for bass you can feel while preserving drive unit longevity.
Aluminum pole piece extension improves thermal management properties for exceptional heat dissipation.
Dual layer voice coil design maximizes linearity and accuracy at full excursion while minimizing distortion and power compression.
Using the same amplifier technology as the flagship SVS 16-Ultra Series, PB-1000 Pro features a 325 watts RMS, 820+ watts peak power Sledge STA-325D amplifier with fully discrete MOSFET output.
-325 watts RMS continuous (820+ watts peak dynamic)
-Sledge STA-325D DSP amplifier
–High Current Output from Fully Discrete MOSFETs with Efficiency of Class D Amplifier allows the Sledge STA-325D amplifier to move massive amounts of current enabling immense output with surgical precision.
–Sophisticated 50Mhz High Resolution Analog Devices Audio DSP is the most advanced digital Processor ever used in a subwoofer and maintains pinpoint accuracy and pristine sound quality through advanced in-room tuning, powerful DSP controls and more.
-Freq Response: 17-260 Hz +/- 3 dB (Standard Mode)
-Freq Response: 19-260 Hz +/- 3 dB (Sealed Mode)
-Expect 2-3 Hz deeper extension in small to mid-size rooms.
Speaker Level Stereo Input
Smartphone App – Easiest Way Ever to Manage Subwoofer DSP and Control.
3 custom presets – one-touch tuning optimized for music, movies, gaming, and more.
2-way feedback show updates in real time (app and rear panel of subwoofer)
Connects via Bluetooth
3-band parametric EQ controller
Adjust rossover frequencies, 3-band parametric EQ, polarity, room gain and more, all from your favorite seat.
SVS Intelligent Control Interface (ICI) on the rear panel of the 1000 Series cabinets provide control options for the subwoofer’s most critical functions.
Cabinet Dimensions: 18.9” (479mm) H X 15” (380mm) W X 20” (509mm) D; 19.2” (488mm) D (with grille)
Weight: 23.4kg
3 Years Local Warranty
Welcome for audition @ Subang Jaya SS14. Chong 012 6116917
*SVS latest series
*3-Years Warranty
Weight: 23.4kg
Product info: [You must be registered and logged in to see this link.]
Price: RM4,099 (Black Ash)
» SVS SB-1000 Pro Subwoofer
» KEF PSW 1000.2 powered subwoofer
» SVS PB-1000 Subwoofer (New)
» SVS PB-1000 subwoofer (used)
» B&W ASW 1000 Subwoofer (Used)
