Tachii 3.5mm to 5pin DIN cable for Naim equipment, REAN / Studiolab connectors
Tachii 3.5mm to 5pin DIN cable for Naim equipment, REAN / Studiolab connectors Empty Tachii 3.5mm to 5pin DIN cable for Naim equipment, REAN / Studiolab connectors
Post by RozWorks Hifi Solutions Fri May 07, 2021 12:00 pm
Selling custom made cable using Tachii cable (made in Japan), Studiolab and REAN connectors. This is a 3.5mm to 180degree 5-pin DIN cable. This cable can be used to connect a source with a 3.5mm output connector to a Naim preamp or integrated amplifier input for playback purposes. The 5 pin DIN plugs are 180degree types so check your equipment first before ordering. Alternatively contact us and give us your equipment model numbers and what you want to use the cable for.
The Tachii cable is a two channel cable. 2 core shield x2
- Tin plated annealed copper wire stranded for conductor and drain wire to improve the reliability through long term use. No more color change and deterioration of copper.
- Better crosstalk property among channels by shielding with AL/PET Tape for each channel unit.
- Foil shield on each channel.
- Gold plated Studiolab 3.5mm connector
- Gold plated REAN 5-pin DIN connector (180 degree type)
As for Roz Works, formerly known as Black Octagon on lowyat forums, we've been dealing with vintage hifi repair and cables now for close to 10 years. And pro audio way before that! Look us up
Length: 1 Meter (other lengths available, just ask us)
Price: RM66 for 1m length
Whatsapp: 016-206 8974
Postage is additional via DHL
Link: http://shopee.com.my/rozworks
Link: Tachii 3.5mm to 5pin DIN cable Shopee
Tachii 3.5mm to 5pin DIN cable for Naim equipment, REAN / Studiolab connectors Img_3823
Tachii 3.5mm to 5pin DIN cable for Naim equipment, REAN / Studiolab connectors Img_3820
Tachii 3.5mm to 5pin DIN cable for Naim equipment, REAN / Studiolab connectors Img_3821
Club Member
Club Member
Number of posts : 26
Registration date : 2021-03-16
Tachii 3.5mm to 5pin DIN cable for Naim equipment, REAN / Studiolab connectors Empty Re: Tachii 3.5mm to 5pin DIN cable for Naim equipment, REAN / Studiolab connectors
Post by RozWorks Hifi Solutions Wed Jun 09, 2021 9:35 pm
Club Member
Club Member
