Monitor Audio Gold 300 5G Floorstanding Speaker
Monitor Audio Gold 300 5G Floorstanding Speaker Brand New. Now Selling At RM28,999. Free Shipping Within West Malaysia.
Gold 300
The Gold 300 has been engineered to deliver a true audiophile experience. Premium driver technology taken from our flagship Platinum II speakers has been melded with class-leading cabinet construction to produce a speaker designed to last a lifetime.
Gold 300 is the pinnacle of the range. Its deceptively large cabinet houses a 2½" (64 mm) C-CAM mid-range driver with a MPD high-frequency transducer above and a pair of 8" (203 mm) RDT II bass drivers below, in a true three-way arrangement.
Also featuring a pair of rear-facing HiVe II ports delivering smooth airflow and ample bass reinforcement, Gold 300 is the ideal speaker for larger rooms. Its punch and dynamism are matched only by its subtlety and fidelity – Gold 300’s effortless authority, from a crisp 50 kHz at the top end to an earth-moving 30 Hz at the bottom, makes it perfect for any and all listening requirements.
Key Features
Dual HiVe II ports – improved transient response and tighter bass, due to smoother air-flow
Pureflow silver-plated OFC copper internal cabling – highest quality transfer through the signal chain
Soft touch top trim – giving a luxurious, premium quality furniture grade touch and appearance
Single-bolt-through driver technology – providing increased bracing strength, rigidity and driver/baffle de-coupling
Bespoke magnetic grilles – clean visual styling, virtually acoustically transparent
Custom-made, high-quality gold plated bi-wire terminals
Sturdy cast metal out-rigger feet with spike or rubber foot for carpet or hard flooring – provides more attractive appearance and takes up less floor space
System Format
3-way
Frequency Response (-6 dB)
30 Hz – 50 kHz
Sensitivity (1W@1M)
90 dB
Nominal Impedance
4 Ohms
Minimum Impedance
3.5 Ohms @ 1 kHz
Maximum SPL
117 dBA (Pair)
Power Handling (RMS)
250 W
100 – 250 W
Bass Alignment
Bass Reflex
Dual HiVe II port system
Crossover Frequency
L.F/ M.F: 650 Hz
M.F/ H.F: 3 kHz
Drive Unit Complement
2 x 8" RDT II long-throw bass driver
1 x 21/2" C-CAM mid-range driver
1 x MPD high-frequency transducer
External Dimensions (Including Grille and Terminals (H x W x D))
1000 x 240 x 360.6 mm (393/8 x 97/16 x 143/16")
External Dimensions (including Outrigger Feet and Spikes (H x W x D))
1047 x 327.8 x 417.8 mm (411/4 x 127/8 x 167/16")
Weight (each)
30.56 kg (67 lb 4 oz)
Sold As
Pair
Gold 300
Key Features
- MPD high frequency transducer – articulate, extended high frequencies, yet supremely smooth
- Dual 8" bespoke bass drivers, featuring:
- – RDT II Cone technology – specially developed Sandwich cone technology using thin C-CAM, Nomex honeycomb core and woven carbon fibre back skin to return incredible stiffness, yet light and well damped
System Format
3-way
30 Hz – 50 kHz
Sensitivity (1W@1M)
90 dB
Nominal Impedance
4 Ohms
Minimum Impedance
3.5 Ohms @ 1 kHz
Maximum SPL
117 dBA (Pair)
250 W
100 – 250 W
Bass Alignment
Bass Reflex
Crossover Frequency
L.F/ M.F: 650 Hz
M.F/ H.F: 3 kHz
Weight (each)
Sold As
Pair
- Number of posts : 1318
» Monitor Audio Gold 300 Floorstanding Speaker
» Monitor Audio Bronze 5 Floorstanding Speaker
» Monitor Audio Bronze 6 Floorstanding Speaker
» Monitor Audio Monitor Gold 7 Bookshelf Speaker (Sold)
» Monitor Audio Silver 300 Floorstanding Speaker
