NAD C 165BEE Stereo Preamplifier
NAD C 165BEE Stereo Preamplifier Brand New. Now Selling At RM5,299. Free Shipping Within West Malaysia.
Distinguished amongst analogue preamplifiers, the C 165BEE is built to be the heart of any advanced home audio system. Starting with six line level inputs, including MC/MM phono input, the C 165BEE is incredibly flexible. Featuring a superbly designed tone control circuit, the C 165BEE is an exceptional example of how to implement high-fidelity tone controls by affecting only the frequency extremes and leaving the critical midrange untouched, while also offering a bypass option. With a 12V-trigger output and IR inputs and outputs on the rear panel, the C 165BEE is ready to integrate with CI control systems. With outstanding build quality and true engineering sophistication, the NAD C 165BEE is the preamp you’ve been waiting for.
C 165BEE是模拟前置放大器中的佼佼者,是任何高级家庭音响系统的核心。C 165BEE有6个线级输入,包括MC/MM声道输入,灵活性极高。C 165BEE拥有一个设计精良的音色控制电路,它是如何实现高保真音色控制的杰出典范,只影响极端频率而不触及关键的中音,同时还提供了一个旁路选项。C 165BEE的后面板上有一个12V触发输出和红外输入和输出,可与CI控制系统集成。NAD C 165BEE是您期待已久的前级放大器
Key Features
Line Level Input
Input Impedance (R and C)
100 kilohm+ 320 pF
Input Sensitivity
158mV (ref. 500mV out)
Maximum input signal
9V
Signal/Noise Ratio, A-weighted
108dB (ref. 500mV in 500mV out, volume set to unity gain)
112dB (ref. 2V out, Volume maximum)
Frequency response
± 0.1dB (ref. 20Hz – 20kHz, Tone defeat ON)
± 0.5dB (ref. 20Hz – 20kHz, Tone defeat OFF)
Frequency response (subwoofer out)
100Hz (ref. -3 dB)
Output
Output Impedance
Pre-out
75 Ohm
Tape out
Source Z + 440 Ohm
Sub out
100 Ohm
Headphones
10 Ohm
Maximum Voltage Output
Pre-out
>10V into 600 Ohm
Tape out
>10V into 10 kilohm load
Sub out
>7V into 1 kilohm load
Headphones
>5V into 600 Ohm
>2V into 32 Ohm
HD (CCIF IMD, DIM 100)
>0.001% dB (ref. 20Hz – 20kHz, 2V out)
Tone Controls
Treble
±5dB at 10kHz (ref. 2V in 500mV out)
Bass
±5dB at 100Hz (ref. 2V in 500mV out)
Phono Input
Input impedance
MC
40, 100, 600 Ohm (R)
1nF (C)
MM
47 kilohm (R)
220, 300, 400pF (C)
Input sensitivity
MC
0.15mV (ref. 1kHz 500mV out)
MM
2.63mV (ref. 1kHz 500mV out)
Input overload
MC
1mV/10mV/100mV (20Hz/1kHz/20kHz)
MM
16mV/147mV/1.4V (20Hz/1kHz/20kHz)
Gain – Tape out
MC in
59.8dB1 (ref. 1kHz, 10 kilohm load)
MM in
36.5dB (ref. 1kHz, 10 kilohm load)
THD (CCIF IMD, DIM 100)
0.009% (ref. 20Hz – 20kHz, 5Vrms Tape out)
Signal/Noise ratio, IHF A-weighted
MC
78dB2 (ref. 0.5mV)
MM
86dB3 (ref. 0.5mV)
RIAA response accuracy
± 0.5dB (ref. 20Hz – 50Hz)
± 0.3dB (ref. 50Hz – 20kHz)
Infrasonic filter
10Hz (at -3dB)
5Hz (at -14dB)
Channel Separation
>60dB (ref 1kHz/10kHz)
>60dB (ref. 1kHz/10kHz)
Physical Specs
Dimensions (W x H x D)
Net
435 x 80 x 286mm (17 1/8 x 3 x 11 1/4”)
Gross*
435 x 99 x 315mm (17 1/8 x 3 15/16 x 12 1/2”)
Net weight
13.23lb (6kg)
Shipping weight
17.1lb (7.8kg)
*Gross dimensions include feet, extended buttons and rear panel terminals.
C 165BEE
Stereo PreamplifierDistinguished amongst analogue preamplifiers, the C 165BEE is built to be the heart of any advanced home audio system. Starting with six line level inputs, including MC/MM phono input, the C 165BEE is incredibly flexible. Featuring a superbly designed tone control circuit, the C 165BEE is an exceptional example of how to implement high-fidelity tone controls by affecting only the frequency extremes and leaving the critical midrange untouched, while also offering a bypass option. With a 12V-trigger output and IR inputs and outputs on the rear panel, the C 165BEE is ready to integrate with CI control systems. With outstanding build quality and true engineering sophistication, the NAD C 165BEE is the preamp you’ve been waiting for.
Performance Far Beyond Expectation
The C 165BEE is an all-new design representing a lifetime of design experience from NAD’s renowned Director of Advanced Developments, Bjørn Erik Edvardsen. New semi-conductors and improved production techniques such as surface mount devices (SMDs) have created opportunities for performance far beyond expectation when compared to previous products in this price range. Compared to its predecessor the C 162, an improved tone control circuit and revised PCB layout has reduced distortion and noise to unprecedented levels when combined with the high signal capacity of the NAD Class A Gain Modules.远远超过预期的性能
C 165BEE是NAD著名的高级开发总监Bjørn Erik Edvardsen的全新设计,代表了NAD一生的设计经验。新的半导体和改进的生产技术(如表面贴装器件(SMD))为该价格区间的产品创造了远超预期的性能。与前代产品C 162相比,改进后的音色控制电路和改进后的PCB布局与NAD A类增益模块的高信号容量相结合,将失真和噪声降低到了前所未有的水平。Interested please feel free to contact:
Key Features
- 6 Line Level Inputs
- Phono Input with selectable Moving Coil and Moving Magnet sensitivity settings
- 3 position Resistance and Capacitance settings for Phono Input
- 2 Line Level Outputs, one variable from 0dB to -12dB
- Subwoofer Output
- Independent Headphone Amplifier
- Pure Class A Gain Modules
- Sealed Reed Relays for Input Switching
- Heavy Gauge Steel Chassis
- Bass and Treble Controls with Defeat Switch (bypass]
- Gold Plated Sockets
- 12V Trigger Output
- IR In and Out
- Detachable Power Cord
- SR 8 NAD 4 Device System remote Control
- <1 watt Standby Consumption
Line Level Input
100 kilohm+ 320 pF
Input Sensitivity
9V
Frequency response
100Hz (ref. -3 dB)
Output
Output Impedance
Pre-out
75 Ohm
Tape out
Source Z + 440 Ohm
Sub out
100 Ohm
Headphones
10 Ohm
Pre-out
>10V into 600 Ohm
Tape out
Sub out
Headphones
>5V into 600 Ohm
>2V into 32 Ohm
Tone Controls
Treble
Bass
Phono Input
Input impedance
MC
1nF (C)
MM
47 kilohm (R)
220, 300, 400pF (C)
Input sensitivity
MC
MM
Input overload
MC
MM
Gain – Tape out
MC in
MM in
MC
78dB2 (ref. 0.5mV)
MM
86dB3 (ref. 0.5mV)
Infrasonic filter
10Hz (at -3dB)
5Hz (at -14dB)
Channel Separation
Physical Specs
Net
Gross*
Net weight
13.23lb (6kg)
Shipping weight
17.1lb (7.8kg)
- Number of posts : 1342
» Yamaha C-1 Stereo Preamplifier and Yamaha B-1 Stereo Power Amplifier (Used)
» Yamaha C4 Stereo Preamplifier (Used)
» Onkyo P-308 Stereo Preamplifier (PL)
» Bryston BP-16 Stereo Preamplifier (Used)
» Bryston BP-17 Stereo Preamplifier
