ToneWinner AD-3Pro Class A 150W Integrated Amplifier
ToneWiner AD-3Pro, Full balance Class A Hi-Fi stereo amplifier rated 150W (8ohms)
Based on ToneWinner flagship hi-fi series AD-1Pre & AD-1PA design, AD-3Pro heritage it's design combine with modern audiophile grade components and circuit design~
For better sound presentation , AD-3Pro can switch Class A to Class AB , depending on the music. Just like Danish high end amplifiers~
To ensue the continues 150W (8ohms),
AD-3Pro's 24pieces high output Toshiba transistors can drive most demanding loudspeaker. It also support Speaker A , Speaker B or Speaker A+B.
AD-3Pro using most premium NJW1195A volume audio switch, with attenuation 0.5db per steps. Together with BurrBrown OP1656 ultra noise, ultra low jitter operation amp to deliver precise and accurate sound.
As a modern amplifier AD-3Pro comes with advance digital board, ESS Sabre ES9038 D/A Converter able to playback Hi-Res audio files.
AD-3Pro also design for Vinyl enthusiast, it support PHONO STAGE MC/MM input.
You can enjoy 2.1ch system~ AD-3Pro comes with fully balance XLR and unbalance RCA Subwoofer output.
Solid heat sink, rigid chassis and alloy dampening feet are the good foundation to suppress unwanted resonance noise and provide better noise floor.
AD-3Pro, class A 150W amp, 31kg weight amplifier fulfill most of the hi-fi enthusiast needs.. not only performance, and it is really affordable price in this category~
Price RM 8,750 with 36month warranty
Call 012-2499823 David Low
david kestez- Club Member
- Number of posts : 35
Registration date : 2020-06-04
» Tonewinner AD-1PA Class A 2Ch HIFI Power Amplifier (Used)
» ToneWinner AD-86D Integrated Amplifier
» Bow WaZoo Class A Integrated Amplifier ( Used )
» YBA Integre DT Class AB Integrated Amplifier ( Used )
» Luxman L-560 Class-A Integrated Amplifier
