SOLD-4K UHD Laser Smart Home Theater CineBeam Projector
KEY FEATURES :
+4K UHD (3840 x 2160) Resolution
+Up to 300’’ of Projection Screen Size Dual Laser with Lens Shift
+2700 ANSI Lumens
+2,000,000:1 Contrast
+HDR10 & HLG
+HDMI 2.1
@The projector displays high resolution images via its HDMI 2.1 connection, with the ability to produce 10-bit images to 4:4:4 RGB specifications.
+HDR pro Covers HDR10, Dynamic Tone Mapping, HLG, and HGiG
@HDR pro improves quality by making bright parts of an image brighter and the dark parts darker, while maintaining detail. The CineBeam is compatible with HDR10 and HLG formats, as well as Dynamic Tone Mapping and HGiG.
+eARC
@Enhanced Audio Return Channel (eARC) delivers up to 32 channels of audio, including 8-channel, 24-bit/192 kHz uncompressed data streams at speeds of up to 38 Mb/s
+XPR Technology Projects UHD Resolution
@XPR technology combines image processing with the ability of the DMD's mirrors to shift at the microsecond level to allow each mirror to project multiple pixels per frame, creating a 4K UHD image from an otherwise non-UHD chip.
+Exceptional Picture Quality
@With 8.3 million pixels utilizing 4K UHD laser technology, the LG CineBeam delivers impeccable precision and detail on up to a 300" screen. With a 2,000,000:1 dynamic contrast ratio, the CineBeam can express deep blacks. It also accurately represents colors, thanks to a wide color gamut that meets 97% of the DCI-P3 color space.
+Designed for Both Bright and Dark Environments
@Depending on the lighting condition of your viewing environment, you can change the iris mode. Dark Room Mode optimizes brightness for use in dark rooms, with lower black levels, while Bright Room Mode increases white and black levels for vivid images.
+Adaptive Contrast Fits Laser Output to the Scene
@Adaptive Contrast gives more depth to your image by adaptively adjusting the laser output to the image in order to create a high contrast ratio. Bright scenes appear brighter, while dark scenes remain detailed with deep blacks and shade detail.
+Filmmaker Mode
@Filmmaker Mode turns off motion smoothing and other video processing settings, so the projector can faithfully and accurately deliver the creator's intended vision.
+The Smart Way to Access Content
@With webOS 5.0, you can explore a variety of TV shows and movies with a simple connection to your Wi-Fi network. You can also enjoy video content with built-in apps like YouTube, Amazon Prime, and Disney+.
+Flexible and Easy Installation
@With lens shift and zoom functionality, you can install the projector virtually anywhere and set the screen to the exact size and location.
Conditions: Brand New
Price: sold
Can order at Shopee(10% coin cashback) OR Lazada. (Put cursor at shopee/lazada for the link)
What@pps me @ zero 1 three nine 1 five four 9 three 2
Last edited by shirogawa on Sun Feb 27, 2022 4:28 am; edited 2 times in total (Reason for editing : SOLD)
shirogawa- Club Member
- Number of posts : 41
Registration date : 2017-03-03
Re: SOLD-4K UHD Laser Smart Home Theater CineBeam Projector
UP. Price can still nego.
» Optoma HD83 Projector 1080P Home Theater Projector (Faulty)
» WTS: Epson Home Cinema TW8300w WirelessHD 3LCD Home Theater Projector
» Optoma hd27 Home Theater Projector (Used) SOLD
» Optoma hd 33 1080P Home Theater Projector (used)(SOLD)
» OPTOMA HD50 home theater projector (sold)
