Roger Modjeski's Music Reference RM-10 Stereo Tube Power Amplifier
Item: Roger Modjeski's Music Reference RM-10 Stereo Tube Power Amplifier
Price: SOLD or swap/topup
Click here to Whatsapp:
http://wasap.my/60123816611
Reviewer: Tom Lyle
All my other items for sale:
CD Player/Streamer:
Bluesound NODE 2021 Wireless Multi-Room Hi-Res Music Streamer @ RM2699
DAC:
Antelope Audio Zodiac+ HD Mastering 192 kHz D/A Converter/ Pre-amp @ RM4600
Lampizator Big 7 5th Gen DSD DAC @ RM28k
TOPPING E30 USB DAC @ RM450
Cambridge Audio DacMagic @ RM850
Phono Stage:
AV Processors/Receiver:
Denon AVC-X8500H Receiver @ RM15,900
Pioneer LX-88 Receiver @ RM3650
Pre Amplifier:
Herron Audio VTSP-1 Tube Preamp @ RM6900
Bryston BP17 Preamplifier @ RM7800
Melos SHA-1 Tube Preamp/ Headphone Amplifier @ RM2200
Music Reference RM-5 Mk4 Tube Preamplfier @ RM4000
Jeff Rowland Capri S1 Preamplifier w Phono @ RM6300
Power Amplifier:
Music Reference RM-10 Power Amplifier @ RM7800
Rogue Audio Magnum M-120 Monoblock Power Amplifier @ RM8500
Naim NAP-155xs Power Amplifier @ RM4200
Naim NAPSC Power Supply @ RM1500
Sanders Magtech Stereo Power Amplifier @ RM12,800
XTZ Edge A2-300 Power Amplifier @ RM2300
Integrated Amplifier:
Devialet D200 Integrated Amplifier @ RM20k
MONA A1 Class A KT120 Tube Single-Ended Integrated Amplifier With Bluetooth 5.0 @ RM2,100
SPEC Corporation RSA-M3EX Integrated Amplifier @ RM29k
Thiel CS3.6 Floorstanding Speakers @ RM7500
Rogers LS66 Bookshelf Speakers @ RM1500
Dynaudio Contour S5.4 Floorstand Speakers
Odeon Audio Orfeo Bookshelf Speakers @ RM7500
PSB Imagine X2T Tower Loudspeakers @ RM5500
Sonus Faber Venere Center Speaker @ RM2,200
Speaker Stand:
Guizu Solid Teak Wood Speaker Stand with Cast-iron Base and Spikes @ RM1000
Custom-made 6-Columns Audiophile Bookshelf Speakers Stands @ RM1600
Speaker Cables:
ASI Liveline Speaker Cables - 3.4m @ RM
XLO Ultra 12 Bi-wire Speaker Cable - 6 feet pair @ RM1500
Xindak FS-1 Speaker Cable - 2.5m @ RM1200
XLO Ultra 6 Speaker Cables - 6 feet pair @ RM900
Taralabs The One
Subwoofers:
JL Audio Dominion D-110 10"Inch Powered Subwoofer - 750W (Black Ash) (NEW) @ RM5500
JBL
Interconnects:
FURUTECH FireBird-96 ( 9pin-6pin ) IEEE1394 Fire Wire Cable 0.6m @ RM450
Cardas Audio Lightning 15 75 ohm SPDIF Coaxial Digital Cable - 1.5m @ RM1350
Transparent Audio
Taralabs The One
Audioquest Diamondback RCA Interconnect - 1m @ RM380
Shunyata Research Cobra XLR Interconnect - 1.5m @ RM3300
Cardas Cross XLR Interconnect - 1m @ RM680
NBS Professional IV Digital AES/EBU Cable - 1m @ RM3800
Black Rhodium Twist RCA Interconnect - 1.5m @ RM250
Power Cables:
Tice Power Cord Model "Power Conductor 2"- 2.5m @ RM1500
Furutech NanoFlux Power Cord - 1.8m @ RM8500
Vitus Andromeda Power Cord - 1.5m @ RM3600
ASI Liveline Power Cable - 1.8m @ RM2700
Shunyata Research Diamondback Platinum Power Cable - 20A @ RM690
Shunyata Research Etron Cobra Power Cable - 20A @ RM2200
Aural Symphonics 20A Missing Link Cubed Power Cable @ RM1900
Power Conditioner:
Torus IS Toroidal Isolation Power Transformers @ RM8300
Others:
JL Audio JLINK TRX: Wireless, High-Fidelity Audio Transmitter & Receiver Kit @ RM1290
Solid Tech Feet Of Silence (Set of 4) NEW @ RM1500
Subwoofer Base Vibration Isolation Platform @ RM690
Graham Slee - Solo Ultra-Linear Headphone Amplifier + PSU1 Power Supply @ RM1800
CAN VIEW THE DETAILS HERE:
Reviewer: Tom Lyle
CD Player/Streamer:
DAC:
Phono Stage:
Pre Amplifier:
Power Amplifier:
Speaker Stand:
Speaker Cables:
Taralabs The One
Subwoofers:
JBL
Interconnects:
Transparent Audio
Taralabs The One
Power Cables:
Power Conditioner:
Others:
» Roger Modjeski's Music Reference RM-10 Stereo Tube Power Amplifier
