Aurum Cantus V8F(used)delate
Aurum Cantus V8F
Model :V8F
open box condition,new never use b4 keep in store long time
come with all original packaging
Condition :9/10
Price : rm delate
Contact : 0146206422 whatapp
kelana jaya
Technical data:
l Design:3-way vented-box
l Frequency Response:35Hz-40kHz
l Sensitivity (2.83V/1m):88dB
l Impedance:8 ohms (minimum 6.4 ohms)
l Power Requirement:50-250W recommended
l Tweeter:Model: G1. Purified aluminum ribbon tweeter, the size of aluminum ribbon
(LWT): 150mm×14.5mm×0.01mm. High power handling, high output, shielded design, easily field-replaceable for the ribbon.
l Midrange: Model: AC165AVM/50SC, 1×165mm (6.5″). Aluminum frame, the
sandwich cone of Non- woven carbon fiber+Cell+Non-woven carbon fiber, 50mm (2″) copper clad aluminum voice coil with flat wire, the special magnet system with Faraday ring and demodulation coil, 120mm×20mm Y30 Ferrite magnet.
l Woofer:Model: AC200AVM/75C2C, 1×200mm (8″). Aluminum frame, the sandwich
cone of Non-woven carbon fiber+Cell+Non-woven carbon fiber, 75mm (3″) copper clad aluminum voice coil with flat wire,the special magnet system with Faraday ring and demodulation coil, 170mm×22mm Y30 Ferrite magnet.
l Crossover Frequency:150Hz and 2100Hz
l Crossover’s Attenuation Slope:Woofer -12dB, Midrange -12dB, Tweeter -18dB
l Crossover Components:M-Cap Supreme MKP capacitors are used for crossover of
tweeter, Aurum Cantus MKP capacitors and nonpolarity electrolytic capacitors are used for the crossover of midrange and woofer. Also, high purified OFC inductors and the metal oxide film resistors with military industrial standard.
l Connective Cable:Teflon insulated OCC cable
l Damping Material:The polyester fiber and the PU foam
l Connections:4 pcs 18mm gold-plated copper connectors, Bi-wiring
l Cabinet Material:High quality MDF
l Finish: The standard finish is Rosewood PE high gloss paint. Furthermore, there are also
Figured maple PE high gloss paint, Cherry PE high gloss paint and the Black PE high gloss paint for options.
l Dimensions (HWD):1100mm×352mm×462mm (43.3″×13.86″×18.19″).
l Net Weight:53kgs/pc (116.85lb/pc)
l Gross Weight:
l Shipping Volume:
Last edited by joe79 on Sat Nov 26, 2022 12:43 pm; edited 3 times in total (Reason for editing : delate)
joe79- Dealer\Reseller\Trader\Service Provider
- Number of posts : 381
Registration date : 2010-04-06
» aurum cantus leisure 5
» Aurum Cantus Leisure 6 ( hardly used)
» Aurum Cantus Leisure 6 Biwire
