Monitor Audio R352 Stereo Speaker Designed by Robin Marshall
price : RM 1580
contact Simon Ting : 012-3612507
Made In England
Design by Robin Marshall ( Epos 14)
System Type: Reflex
Frequency Range: 35 Hz - 20 kHz
Frequency response: 50 Hz - 20 kHz ±3 dB
Impedance: 8 Ω
Sensitivity: 91 dB
Recommended Amp. Power: 15 - 120 watts
Dimensions (H x W x D): 640 x 250 x 318 mm
Weight: 13,0 kg
Finishing : Black
The large size of the R352 with its furniture-finished real wood veneer is a dramatic sight to behold. Listening to the R352 is no less impressive.
The R352 is a two-way bass reflex design with specially built woofers incorporating uniquely shaped megnets resulting in low-mass bass-midrange drivers that are highly efficient, fast and capable of producing deep tight bass. The cabinets are heavily braced and precisely lined with ¾ inch acoustic foam producing an uncommonly dead box, particularly considering the size.
Both the woofer and tweeter are mounted to the front baffle using T-bolts, thus ensuring a good, tight fit. Internal wiring is with Monitor Audio 100 strand cooper cable. The efficiency of the R352, coupled with its high power handling capabilities, means that very high levels can be producedeven when using moderately sized amplifiers and receivers. Listening to them is to be truely impressed by their dramatic, dynamic, powerful and accurate presentation of your favorite music.
"any criticisms? None really. They will show you how good your system is, but can also be used with cheaper, low powered equipment … fro a sound and build quality point of view they offer excellent value for the money, and are comparable with speakers costing much more."
David Berriman Hi-Fi Sound
- Number of posts : 2967
» Monitor Audio R300MD England Made Standmount Bookshelf Speaker Designed by Robin Marshall
» WTS : Monitor Audio RS6 floorstander + Cambridge Audio Stereo Amp 640A Ver 2
» Monitor Audio Monitor Gold 7 Bookshelf Speaker (Sold)
» Coleman audio TB4 MKii. Stereo monitor controller. (used)
» Monitor Audio Monitor 7 Gold Bookshelf Speaker
