Focus Audio MT1 Floorstand Loudspeakers (Used) SOLD
Focus Audio MT1 Floorstander
The Focus Audio speakers are finished in a very attractive piano-black finish. The cabinets feature 2"-thick front baffles and 1"-thick side walls, which results in quite inert construction. The cabinets do appear to be very well braced, as they are exceptionally sturdy. The MT1 use two 5.5" Nomex/Kevlar bass/midrange units sourced from Germany and a 1.125" soft-dome tweeter from Denmark. According to Kam Leung of Focus Audio, two smaller drivers allow for higher power handling than one larger unit -- a necessity for home-theater applications. The drive units are all matched to within +/- .25dB. Crossover components utilize polypropylene and polystyrene capacitors with "ultra-purity" copper coils, and are tested to be within a 1% tolerance. Silver solder is used throughout each loudspeaker for all internal connections.
Manufacturer-rated sensitivity is 89dB with a nominal impedance of 4 ohms for MT1, Focus Audio states frequency response that extends down to 40Hz for the MT1. MT1 feature Cardas high-purity-copper binding posts.
SPECIFICATIONS :
- - Piano-Bird Eye Mable finish
- - Heavily braced MDF cabinets
- - 2"-thick front baffle and 1"-thick cabinet walls
- - Scan-Speak soft-dome tweeters
- - Eton Nomex/Kevlar woofers
- - Crossovers use polypropylene and polystyrene capacitors
- - Silver solder used on internal connections
- - Cardas binding posts
- - Dimensions: 36"H x 7"W x 10"D
- - Weight: 42 lbs each side
- Made In Canada
- Condition: 7.5/10
- Asking: RM Sold
- Interested please contact: Khim 016-3662081
Last edited by KhimAudio on Fri Nov 12, 2021 11:47 am; edited 1 time in total (Reason for editing : Item sold. Thank you very much hifi4sale.)
- Number of posts : 2166
» Focus Audio FS 88 Signature Floorstand Loudspeakers (Used) SOLD
» Focus Audio FS888 Signature Series Floorstand Loudspeakers (Used) SOLD
» Focus Audio FS88 loudspeakers (SOLD)
» Focus Audio FC8 Floor Stand Loudspeakers (Used) SOLD
» Focus Audio Signature Series FS7 Loudspeakers (Used) SOLD
