Mission ZX-4 Floorstanding Speaker
Mission ZX-4 Floorstanding Speaker Brand New. Now Selling At RM8,999. Free Shipping Within West Malaysia.
Mission ZX-4 3-Way Floorstanding Speaker Brand New
NEW RING DOME TREBLE UNIT
NEW DIADRIVE BASS/MIDRANGE UNIT
NEW CABINET / DRIVER BRACING SYSTEM
FINE TUNED CROSSOVER PERFORMANCE
Bass Driver 5.25" (130mm) aluminium cone x2
Midrange Driver 5.25" (130mm) aluminium cone
Treble Driver 1.5" (38mm) ring dome
Nominal Impedance 4 Ohms(compatible 8 Ohms)
Sensitivity (2.0V @ 1m) 90dB
Recommended Amplifier Power 25-150W
The ZX Series is the latest in a long line of distinguished and revered Mission loudspeakers and joins more recent Award winning products. The ZX series represents the most technologically advanced loudspeakers in the Mission family, with a distinct ID that will complement the finest electronics and décor.
Mission ZX incorporates purpose designed bass driver cones, precision engineered motor systems, advanced treble units and more. As ever with Mission products; ‘Music leads, Technology Follows’. No compromise.
The result is lower distortion and superior performance, at frequencies up to 30 kHz and beyond. Transient performance is dramatically improved, as is musical detailing, particularly of instrument overtones and harmonics
In ZX the driver surround is covered by a vented cover which controls the spurious output from the diaphragm edge, again improving midrange clarity
Matching ‘serrations’ are built into the flare of the slot port. High pressure airflow is streamlined from the port exit whilst the asymmetric design breaks up the ‘chuffing’ distortion normally heard from circular ports
To improve the mechanical integrity of these magnet systems, special bracing methods have been developed to ensure that the bass diaphragms respond accurately to the musical waveform. Bass output is now thrillingly dynamic with superior detailing and extension
ZX-4
Floorstanding SpeakersThe ZX Series is the latest in a long line of distinguished and revered Mission loudspeakers and joins more recent Award winning products. The ZX series represents the most technologically advanced loudspeakers in the Mission family, with a distinct ID that will complement the finest electronics and décor.
Mission’s Ring Dome treble unit overcomes the problems inherent in conventional domes. With this technology the centre of the dome is fixed and voice coil attached part of the way across the dome. The dome is formed into two rings, with the voice coil in the centre so that it can drive the dome more accurately and efficientlyThe result is lower distortion and superior performance, at frequencies up to 30 kHz and beyond. Transient performance is dramatically improved, as is musical detailing, particularly of instrument overtones and harmonics
Mission’s DiaDrive bass unit has an advanced aluminium matrix cone and is now vented to remove trapped air behind the diaphragm, thus reducing resonance and allowing a clearer midrange performance to beyond 3kHzIn ZX the driver surround is covered by a vented cover which controls the spurious output from the diaphragm edge, again improving midrange clarity
Mission ZX bass/midrange units now feature, as standard, over-size magnet systems to deliver the punch and transient attack that feature in modern recordingsTo improve the mechanical integrity of these magnet systems, special bracing methods have been developed to ensure that the bass diaphragms respond accurately to the musical waveform. Bass output is now thrillingly dynamic with superior detailing and extension
Mission’s Inverted Driver Geometry (IDG) of bass/midrange and treble units has been applied to equalise acoustic path lengths. IAG’s Head of Acoustic Design, Peter Comeau, has worked tirelessly to ensure a seamless integration between the drive units, so the speaker behaves as one music making systemZX CONTINUES TO TELL THE STORY
Designed to stand out head and shoulders above the competition, the Mission ZX range oozes luxury in appealing gloss black and gloss white finishes. Carefully selected trims and driver materials do more than catch the eye and complement the technology at play. The Mission ZX series has an all-inclusive design that continues to tell the story of the music, not just deliver hi-fi soundZX-4 Specifications
General Description | 3-way floorstanding speaker |
Enclosure Type | Bass reflex |
Transducer Complement | 3-way |
Bass Driver | 5.25" (130mm) aluminium cone x2 |
Midrange Driver | 5.25" (130mm) aluminium cone |
Treble Driver | 1.5" (38mm) ring dome |
AV Shield | No |
Sensitivity (2.0V @ 1m) | 90dB |
Recommended Amplifier Power | 25-150W |
Peak SPL | 110dB |
Nominal Impedance | 4 Ohms(compatible 8 Ohms) |
Minimum Impedance | 3.4 Ohms |
Frequency Response(+/-3dB) | 40Hz ~ 24kHz |
Bass Extension(-6dB) | 35Hz |
Crossover Frequency | 530Hz,2.7kHz |
Dimensions (HxWxD) | 1075 x 240 x (350+12)mm |
Net Weight | 24.6kg/pcs |
- Number of posts : 1336
» Mission ZX-5 Floorstanding Speaker
» Mission M34 Floorstanding Speaker(Used)
» Mission LX-6 MKII Floorstanding Speaker
» Mission LX-4 MKII Floorstanding Speaker
» Mission VX4 Floorstanding Speaker (Sold Out)
