Epos K2 Floorstand speaker system, Black
Features highly inert enclosure and frontal slot for improved bass performance
The bass slot makes for a smoother bass response in addition to greatly easing speaker positioning and room placement.
High Velocity Slot Ports (HVSP) achieves lower audible distortion, reduced turbulent airflow within the port.
Dimension: W185 x H865 x D250 mm
Weight : 11.0kg
2.5-way
25mm soft dome tweeter
Dual 156mm polypropylene bass/mid
Power handling 150 watts
4 Ohms impedance
Sensitivity 89dB
Frequency Response: 45Hz – 30kHz
Beautifully clear and transparent mid-range quality with the clever clamping mechanism, uniformed clamping pressure helps to reduce unwanted vibrations.
Epos has achieved very high performance, and a clean, open yet smooth sound quality from the fabric-dome, short horn, high-temperature ferro-fluid cooled voice-coil, and neodymium magnet tweeter.
Elegant silk black finish.
“I have tried numerous GBP1,000 that was new floorstanders in the previous year, and standards are not low. Only at that price point, you are anticipating a variety of electricity management that is serious, broad frequency range with extended bass and treble, a great deal of detail, great soundstaging and delicacy. The K2 has these all, and more – really it is among the most powerful competitors and definitely the most amiable having an easy, even, open sound that makes an immediate line. There is nothing not to enjoy, as well as the choice that is active ought to be a blast.”
In good condition, no dent / cracked corners. Perfect working.
Comes with original spikes and jumpers. (No Box)
RM3200
Welcome for audition
Credit cards accepted.
Subang Jaya ss14.
0126116917
www.facebook.com/Actsessory/
» Epos K2 Floorstand speaker (NEW)
» Epos K2 Floorstand speaker (Used)
» Epos K2 floorstand speaker (s0ld)
» Epos ES22 floorstand speaker
» Epos ES22 Floorstand Speaker (Sold)
