Denon PMA-2500NE Reference Integrated Amplifier (SOLD)
Denon PMA-2500NE Reference Integrated Amplifier (SOLD) Empty Denon PMA-2500NE Reference Integrated Amplifier (SOLD)
Post by choyaudiovisual Wed Nov 03, 2021 10:21 am
Denon PMA-2500NE Reference Integrated Amplifier (SOLD) Img_4910
Denon PMA-2500NE Reference Integrated Amplifier (SOLD) Img_4847
Denon PMA-2500NE Reference Integrated Amplifier (SOLD) Img_4849Denon PMA-2500NE Reference Integrated Amplifier (SOLD) Img_4850
Denon PMA-2500NE Reference Integrated Amplifier (Used)
Spec:
2 x 160 W (4 ohm) output
Advanced Ultra High Current (UHC)-MOS Single Push-Pull Circuit Power Amplifier with new Schottky barrier diodes
DAC Master Clock Design
USB-B input for High Resolution Audio up to 384 kHz / 32 bit and 11.2 MHz DSD
Digital isolator to eliminate high-frequency computer noise on the USB-B
Low noise OLED display for source and sample rate indication
Analog Mode for pure audio reproduction switching off digital audio circuitry and display
Advanced AL32 Processing Plus
Direct Mechanical Ground Construction to minimize unwanted vibration
Chassis construction with 6 independent blocks to eliminate noises
Leakage-cancelling-mounted twin transformers
Main transformer with separate power supplies for analogue and digital circuits
Wide dynamic range playback, supporting high-resolution audio sources
High-grade volume control for precise adjustment
2 Digital Optical and 2 Digital Coaxial inputs
High performance MM & MC Phono Equalizer Amp
https://www.denon.com/en-au/shop/amplifier/pma2500ne
Conditions: 8/10 (USED)
Whatsapp: Choy 012-5685484
Last edited by choyaudiovisual on Fri Jun 17, 2022 11:33 am; edited 1 time in total
Number of posts : 5790
Denon PMA-2500NE Reference Integrated Amplifier (SOLD) Empty Re: Denon PMA-2500NE Reference Integrated Amplifier (SOLD)
Post by choyaudiovisual Wed Dec 01, 2021 8:56 am
Post by choyaudiovisual Fri Dec 24, 2021 8:49 am
Post by choyaudiovisual Wed Jan 26, 2022 8:47 am
Post by choyaudiovisual Wed Mar 09, 2022 8:38 am
