Condition: Item is in MINT condition. No dents or scrathes. Comes with original box, mounting brackets and LED light fixture.
Selling this unit for RM8800 RM8350 or swap/topup
Can Trade-In your Amplifier/
EMI-Absorbing Formula GC-303
•DVD and DVR (Filter 1)
•CD、Cable and SAT(Filter 2)
•TV and Projector (Filter 3)
•Zone 1, 2, 3 • Green
•Breaker indicator • Red
•Digital voltage meter • Red
•Digital amperage meter • Red
•Rear panel
•Input x 1 • Output x 2
•3 Remote control triggers
•Sequence switch
Under the Hood
On the Track
SPECIFICATIONS
15 A Max. 230V AC
http://av2day.com/2015/05/furutech-daytona-303-plc/
https://www.analogueseduction.net/mains-blocks/furutech-daytona-303-6-way-schuko-power-filter.html
•Rear panel
•Sequence switch
[size=27]FEATURES[/size]
The Daytona: 24 Hour Protection for Pro A/V and High Performance EnthusiastsAll enthusiasts are looking for the same qualities: Verisimilitude to the original event, a sense of engagement promoting suspension of disbelief, an immersion in audio and video experience. To engage without effort requires meticulous preparation of the entire playback chain especially including the AC mains supply.
Under the Hood
On the Track
SPECIFICATIONS
15 A Max. 230V AC
» Furutech Daytona 303 Multi-Mode AC Filter/Power Distributor
