Complete Vintage Tube HiFi system
A matched complete audio system perfect for near field listening or in a proper audio room. Sufficient headroom from the RS-199B tube amp even though driving a 86dB sensitivity Monitor Audio bookshelf. Volume knob only at 8oclock position (Off position 4oclock, goes 360 degree full cycle). I'm upgrading to a McIntosh + Dynaudio setup so will need to offload this set.
Package 1 Amp + Speaker + CDP RM 3,000.00
Contents:
i) Vintage RCA RS-199B tube amp + two pairs EL84 tubes (JJ and Electro Harmonix)
ii) Volume pot + interconnect amp <-> volume pot.
iii) Teac CD-P1160D.
iv) Monitor Audio 9/Gold.
Package 2 Take all RM 4,300.00
Contents:
v) BOD stands.
vi) 3 meter pair VDH CS122.
FREE DIY Cat5 interconnect cables.
Edit - I'll be away overseas until 27th June 2010, so leave a msg or I'll call you back
Contact details
Jeffry, 012-5628770
Terms: Cash only. Full payment upon deal.
Amp pic + spec- 1
Point to point soldering.
Musicap for output stage.
4-ohm rated output. No problem driving 8 ohm speaker loads.
https://2img.net/r/ihimizer/img541/7563/amp1u.jpg
Amp pic - 2
https://2img.net/r/ihimizer/img412/1873/amp2b.jpg
Amp pic - 3
https://2img.net/r/ihimizer/img576/2299/amp3.jpg
Monitor Audio 9/Gold pic + specs - 1
6 1/4" woofers and 1" gold-dome tweeters.
Rear-ported bass-reflex design.
Frequency Response 35Hz-20KHz
Sensitivity (1W@1W) 89 dB
Maximum S.P.L. (per pair dB) 109
Nominal Impedance (Ohms) 8
Power Handling (Watts, R.M.S.) 100
Recommended Amplifier Requirements (Watts, R.M.S.) 15-100
Crossover (Hz) 3.5KHz
Dimensions (cm, HxWxD) 40x20x24
Weight (kg) 18
https://2img.net/r/ihimizer/img203/9209/spk1.jpg
Monitor Audio 9/Gold pic - 2
https://2img.net/r/ihimizer/img27/6089/spk2.jpg
Teac CD-P1160D + spec pic
Plays CD, CDRW
No remote control
https://2img.net/r/ihimizer/img688/3097/teaccdp.jpg
Van den Hul CS 122 pic
https://2img.net/r/ihimizer/img404/3596/vdhq.jpg
BOD Stand pic + spec
60cm ~ 2ft tall.
Attached four spikes at base.
Pre sand filled.
https://2img.net/r/ihimizer/img257/262/standeg.jpg
AC Cable - MK Tough Plug pic + spec
Shielded AC cable.
MK Tough Plug - UK style pins.
https://2img.net/r/ihimizer/img580/1889/pwrcable.jpg
Contents:
Contents:
v) BOD stands.
Contact details
Jeffry, 012-5628770
Amp pic + spec- 1
Amp pic - 2
Amp pic - 3
Weight (kg) 18
Plays CD, CDRW
No remote control
60cm ~ 2ft tall.
Pre sand filled.
Shielded AC cable.
louyeh- New Member
- Number of posts : 1
Registration date : 2009-04-25
» Complete HiFi System (used)
» Tag Maclaren Aphrodite system complete with stands
» Complete hifi set
» Clearing Complete Hi-Fi System
» Complete Hifi set (sold)
» Complete hifi set
