Furutech NCF Booster-Signal-L Connector & Cable Supporter
Furutech NCF Booster-Signal-L Connector & Cable Supporter Brand New. Now Selling At RM669. Free Shipping Within West Malaysia.
Awards
Cradle-Flat Construction
1. NCF (multi-material hybrid structure) … Audio grade ABS resin (Base) and NCF formulated nylon resin (Cover)
2. Damping mat
3. Vibration transmission shaft (central column)
4. Vibration suppression wall (damping wall) … damping structure to suppress resonance.
5. Air chamber … Internal air pressure suppresses vibration.
※At its lowest setting the cradle is 23mm off the floor or rack surface – check input and output connection heights on the component side.
The new design allows for the cradle to be lowered to much further than previous models making it possible for the NCF Booster-Signal-L to support connections that are usually positioned lower on components like HDMI and USB.
Incorporated into selected Furutech products, NCF features a special crystalline material that has two 'active' properties. First, it generates negative ions that eliminate static. Second, it converts thermal energy into far infrared. Furutech combines this remarkable material with nano-sized ceramic particles and carbon powder for their additional 'piezoelectric effect' damping properties. The resulting Nano Crystal² Formula is the ultimate electrical and mechanical damping material. Created by Furutech, it is found exclusively in Furutech products.
Overall Base Unit Dimensions: 89.8 x 66.0mm approx.
Overall Dimensions: W 46 X L 106 X H 23.8mm approx.
Net Weight:
Base level-130.5g / Extended level- 177.5g approx.
Connector & Cable SupporterAwards
2. Damping mat
RATING
Not a Sound Enhancer – A Sound Revealer!The new design allows for the cradle to be lowered to much further than previous models making it possible for the NCF Booster-Signal-L to support connections that are usually positioned lower on components like HDMI and USB.
FEATURES
Nano Crystal² Formula (NCF).Incorporated into selected Furutech products, NCF features a special crystalline material that has two 'active' properties. First, it generates negative ions that eliminate static. Second, it converts thermal energy into far infrared. Furutech combines this remarkable material with nano-sized ceramic particles and carbon powder for their additional 'piezoelectric effect' damping properties. The resulting Nano Crystal² Formula is the ultimate electrical and mechanical damping material. Created by Furutech, it is found exclusively in Furutech products.
SPECIFICATIONS
Height: Base level- 23.8 mm/ Extended level- 81.4 mm approx.Overall Base Unit Dimensions: 89.8 x 66.0mm approx.
Net Weight:
- Number of posts : 1342
» Furutech NCF Booster Signal L Performance-enhancing Connector & Cable Holder
» Furutech NCF Booster Signal (Sold)
» Furutech FI-11 [Cu]/(G)/(R) IEC & FI-11M AC Connector(New)
» Isotek 'Elite' Power Cable 1.5 Meter with Furutech FI-15-G connector (Used) and Others SOLD
» Furutech T-13A (R) Fuse for UK 13A Connector(New)
