Marantz PM-75 Integrated Amplifier with Built-In Philips TDA1541A DAC
2 posters
Item: Marantz PM-75 Integrated Amplifier with Built-In Philips TDA1541A DAC
Condition: 8.5/10. Item is in excellent condition. No dents or scratches. Audiophile Marantz PM-75 integrated stereo amplifier with built-in Philips TDA1541A d/a converter. One owner from new.
The Marantz PM-75 amplifier delivers 100 watts per channel (8 ohm) and features include a phono input (MM / MC) and tone control.
Price: RM1750 or swap/topup
Can Trade-In your Amplifier/
The Integrated Amplifier which carries a digital analog converter.
A version LSI (TDA1541A) which Philips is proud of is adopted as a digital analog converter, and the digital signal is made to link to a highly precise analog circuit.
Thorough serious consideration of the S/N was carried out at the volume part, and the 4-unit master volume is adopted.
Moreover, the final stage of an amplifier part has adopted the three-step Darlington parallel push pull.
A large-sized transformer and capacitor are carried in the power-source part.
In order to prevent the wraparound of a digital noise, the D/A independent-source circuitry is adopted, and the analog system serves as a high stable high speed power source which made full use of high-integrated IC of a low-noise wide band.
The side panel of die-casting is adopted as a sub-.
Furthermore, die-casting framing which eliminated the ill effect of the oscillation is adopted, and the fine oscillation of the circuit board is also effectively controlled by the newly developed vibration suppression substrate material.
Digital one corresponds to three optical 1 coaxials, and the input unit supports all sampling-frequency 32/44.1/48kHz signals.
Moreover, the analog input serves as a design corresponding to the multi-source having those with seven line, and a Phono equalizer (MC, man month). The tapes circuitries are two analogs which can do mutual dubbing freely.
A tone control circuit is the shelving type which set center frequency as 60Hz and 15kHz, is suppressing an elevation of an unnecessary band, and it is considered so that a distorted incrementation and inflow of a noise may be prevented.
The Source-Direct functionality is carried, each stage to flat amplifier is jumped, and not only the output of a digital analog converter but analog output can be directly linked with a master volume.
The Jitter absorbing circuit is carried so that the fluctuation of the optical digital signal by oscillation of an optical cable etc. (Jitter) may be rectified.
The remote control which summarized the functionality compactly is equipped standardly.
Power output: 100 watts per channel into 8Ω (stereo)
Frequency response: 10Hz to 150kHz
Total harmonic distortion: 0.008%
Input sensitivity: 0.25mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 72dB (MC), 83dB (MM), 105dB (line)
Digital inputs: coaxial, optical
Dimensions: 454 x 151 x 379mm
Weight: 16.8kg
https://www.vintagechief.com/marantz-pm-75-amplifier-21522
https://audio-database.com/MARANTZ/amp/pm-75-e.html
Weight: 16.8kg
Re: Marantz PM-75 Integrated Amplifier with Built-In Philips TDA1541A DAC
can swap with Marantz PM78?
chweet- New Member
- Number of posts : 2
Registration date : 2023-01-30
» Philips CD820 (TDA1541A) sold
» Philips TDA1541A DAC (New)
» Audio Analogue Primo Settanta Integrated Amplifier With Built-in Phono
» (SOLD)Yamaha A-S701 Stereo integrated amplifier with built-in DAC (Silver)
