Sheng Ya Tube Preamp SA-31 & Sheng Ya SP-331 Hybrid Power Amplifier ( Made in China OEM Of Vincent Audio) Sold
Condition: 7/10 Excellent
Qty: Tube Pre Amp & Hybrid Power Amp (1 Set)
Prices Per pc: RM2600/= Negotiable
Calls or WhatsApp: 0174365998
Postage can be arrange.
https://www.carousell.sg/p/tube-preamp-sa-31-1034729912/
https://productz.com/en/vincent-sa-31/p/RyRqB
https://www.youtube.com/watch?v=VHQnYAkA2Bw
https://www.carousell.sg/p/vincent-sp-331-hybrid-power-amplifier-197793770/
https://www.usaudiomart.com/details/649495449-vincent-sp331-hybrid-power-amplifier/
https://www.carousell.sg/p/vincent-sp-331-tube-power-amplifier-150-watt-germany-267247784/
https://www.ebay-kleinanzeigen.de/s-anzeige/vincent-sp-331/1722257379-172-2468
Sheng Ya Tube Preamp SA-31 Specification :
Transmission: 20 Hz – 20 kHz, +/-0.5 dB
Harmonic distortion: < 0.1%, Max. (1 kHz, 1 Watt, Input Sensitivity: 150 mV)
Inputs: 4 x RCA, Input impedance: 47 kOhm, signal-to-noise ratio: > 90db
Outputs: 2 x RCA,
Tubes: 2 x 6922 / ECC88 / 6DJ8
Dimensions (W x H x D): 430 x 80 x 300 mm, 4.5 kg,
Colour: Black.
Sheng Ya SP-331 Hybrid Power Amplifier Specification :
Frequency Response: 10 Hz – 20 kHz +/- 0.5 dB; 10 Hz – 50 kHz +/- 2 dB
Nominal Output Power RMS/8 Ohm: 2 x 150 Watt
Nominal Output Power RMS/4 Ohm: 2 x 300 Watt
T.H.D.: < 0.1 % (1 kHz, 1 Watt)
Input Sensitivity: 1,2 V
Signal-Noise Ratio: > 90 dB
Input Impedance: 47 kOhm
Inputs: 1 x Stereo RCA
Outputs: 4 x 2 Speaker Terminal
Tubes: 2 x 6N16B
Colour: Black
Weight: 19 kg
Dimensions ( W x H x D): 430 x 160 x 450 mm
Thanks
Outputs: 2 x RCA,
Colour: Black.
Tubes: 2 x 6N16B
Colour: Black
Weight: 19 kg
Thanks
Jason Eng- Frequent Contributor
- Number of posts : 130
Registration date : 2020-09-09
» Audio experiment music tube preamplifier & SG 50 tube power amplifier (Used)SOLD
» JC Audio tube preamp and Musical Fidelity Typhoon HP Power Amp (SOLD)
» Xiang Sheng 728a tube pre amplifier.
» Golden Tube Audio Preamp SEP-1 & Power Amp SE-40 (used)SOLD
