Acoustic Revive: RTP-4 Ultimate Power Conditioner
Acoustic Revive: RTP-4 Ultimate Power Conditioner Empty Acoustic Revive: RTP-4 Ultimate Power Conditioner
Post by raymond88 Fri Mar 04, 2022 12:28 pm
Item: Acoustic Revive: RTP-4 Ultimate Power Conditioner
Condition: 8.5/10. Item is in excellent condition.
Price: RM3300 or swap/topup
Can Trade-In your Amplifier/
Acoustic Revive RTP-4
Outlets: 4
Type: Passive
Price: $2,250.00 US
Acoustic Revive: RTP-4 Ultimate Power Conditioner A510
"The Acoustic Revive products have made me a believer in the power of optimizing a system to realize its full musical potential."Jeff Day, The Acoustic Revive Chronicles, Positive Feedback
"The RTP-4 delivers the lowest level details on the recording, better perhaps than any other conditioner available."        Dagogo.com
  • Audio Excellence Award 2008 Top Prize for Accessories
  • Audio Excellence Award 2008 Judge Special Prize
  • Stereo Times Most Wanted Components Award 2008
Principle and Structure
Machined from a single block of 2017 Duralumin!
RTP-2, 4 and 6 absolute boxes are made from 2017 Duralumin, which has the best vibration damping characteristic and sound quality.
Comparison of the vibration reduction characteristics of various metals
A machined structure has far better vibration damping characteristics, sound quality and overall lower distortion when compared with metal sheets bolted together to form a box.
The box's maximum thickness is 25mm, making it able to be very highly effectively in shielding the inner structural elements, and yielding a very high S/N ratio.
Acoustic Revive: RTP-4 Ultimate Power Conditioner 8862310
Acoustic Revive: RTP-4 Ultimate Power Conditioner 1553230
Acoustic Revive: RTP-4 Ultimate Power Conditioner 5283930
Acoustic Revive: RTP-4 Ultimate Power Conditioner 8483283
A block of Duralumin weighs 3kg (6.6 Pounds) for RTP-2 absolute, 4kg (8.8 Pounds) for RTP-4 absolute and 6kg 13.2 Pounds) for RTP-6 absolute.
It takes about 5 hours to machine one block and lid for RTP-2 ultimate using a high precision mill, 8 hours for the RTP-4 absolute and RTP-6 absolute.
Eliminates noise and static electricity, non-magnetic!
  • RTP-2, 4 and 6 absolute`s box is filled with Green carborundum, Tourmaline powder and natural quartz powder to eliminate noise and static electricity.
  • Most power supply boxes use a series type noise filter, which converts noise to heat by magnetism which not only absorbs noise, but also absorbs important electrical energy.
  • Also the magnetic body of typical conditioners produces magnetic distortion which adds a distorted feel and thinness to the sound.
  • This is because the electromagnetic wave absorbent material itself is a strong magnetic body.
  • Also parallel type noise filters or choke coils cannot avoid loss in transmitting energy.
  • It may eliminate noise, but it the sense of freedom and energy from the sound.
  • Green carborundum has no such side effects because it is non-magnetic.
  • It only absorbs electromagnetic wave noise which is produced from receptacles and internal wiring.
  • Green carborundum is the only electromagnetic wave absorbent material which improves sound quality and S/N ratio.
  • Tourmaline powder releases negative ions to keep the amount static electricity very low.
  • The natural quartz powder releases far infrared rays which has an surface activation effect. This leads to very realistic and and alive sound.
Acoustic Revive: RTP-4 Ultimate Power Conditioner 4341105
Acoustic Revive: RTP-4 Ultimate Power Conditioner 2471033
Acoustic Revive: RTP-4 Ultimate Power Conditioner 7915670
Here is the Duralumin block after it has been machined. After this it is sand blasted and treated with Snow White Alumite. The lid is grained in and treated with Black Alumite.
Acoustic Revive: RTP-4 Ultimate Power Conditioner 4711012
Acoustic Revive: RTP-4 Ultimate Power Conditioner 6048742
Acoustic Revive: RTP-4 Ultimate Power Conditioner 1606171
Electro magnet absorbing material Green carborundum is placed inside the Snow White Alumite treated chassis.
Acoustic Revive: RTP-4 Ultimate Power Conditioner 1609208
Acoustic Revive: RTP-4 Ultimate Power Conditioner 8361286
Acoustic Revive: RTP-4 Ultimate Power Conditioner 846361
Top quality Lithia tourmaline powder and natural quartz powder gets mixed into Epoxy resin. Instead of using industrial use black tourmaline, for RTP ultimate series, we use top jewel quality Lithia tourmaline which releases more negative ions.
Acoustic Revive: RTP-4 Ultimate Power Conditioner 9655055
Epoxy resin which contains Lithia tourmaline powder and natural quartz powder gets pored on the top of Green carborundum carefully.
Acoustic Revive: RTP-4 Ultimate Power Conditioner 8990647
Acoustic Revive: RTP-4 Ultimate Power Conditioner 1303414
Acoustic Revive: RTP-4 Ultimate Power Conditioner 2177025
Here is the chassis which has set with poured Green carborundum, Lithia tourmaline powder and natural quartz powder. The chassis is left for about a week for the epoxy resin to set.
Acoustic Revive: RTP-4 Ultimate Power Conditioner 1435616
Hollowed out brass foot with 21st century vibration control material!
Underneath the RTP-2, 4 and 6 absolute`s box, there are brass carved out large foot, white are height adjustable. Combination of 2017 Duralumin box and brass foot will eliminate both materials resonance frequency.
To further improve vibration control effect, the vibration control sheet in placed underneath the brass foot. this special material was developed by professor Masao Sumita at Tokyo Institute of Technology with pre-venture support from JST (Japan Science and Technology Agency).
It is an epoch-making material with a powerful vibration control characteristic.
It transfers and eliminates vibration energy by conversion to heat.
A combination of Duralumin, brass leads to the ultimate vibration control structure.
Acoustic Revive: RTP-4 Ultimate Power Conditioner 8168863
Cryogenically treated conductive parts.
The ultimate material for power supply inlet and internal wiring too!
We adopted the ultimate power supply inlet and internal wiring for the RTP-2, 4 and 6 absolute. As with the receptacles, the power supply inlet has been Super cryogenically treated and treated and plated with thick silver and rhodium plating.
The inlet wiring connection is non-solder. ACOUSTIC REVIVE avoids solder connections when possible because it destroys signal transmission..
For internal wiring, we are using our own PCTriple C Copper, oval shaped and very thick.
PCTriple C Copper has superior conductive characteristics. Because it originally is a single core crystal, the chance of absorbing impurities is very low even when it gets annealed.
The oval shaped single core is devoid of the peaky and distorted sound quality normally associated with round, rectangle, or flat shaped conductors.
Acoustic Revive: RTP-4 Ultimate Power Conditioner A113
Acoustic Revive: RTP-4 Ultimate Power Conditioner A213
Acoustic Revive: RTP-4 Ultimate Power Conditioner A313
Acoustic Revive: RTP-4 Ultimate Power Conditioner A413
http://stereotimes.com/access111208.shtml
https://www.lotusgroupusa.com/rtp-series-power-conditioners.html
https://www.dagogo.com/acoustic-revive-rtp-4ultimate-power-conditioner-and-power-reference-power-cable-review/
https://positive-feedback.com/reviews/hardware-reviews/acoustic-revive-rtp-4eu-absolute-ac-power-strip/
http://www.highfidelityreview.com/acoustic-revive-rtp-2-and-rtp-4.html
http://www.acoustic-revive.com/english/rtp/rtp_01.html
Number of posts : 10090
Acoustic Revive: RTP-4 Ultimate Power Conditioner Empty Re: Acoustic Revive: RTP-4 Ultimate Power Conditioner
Post by raymond88 Fri Mar 11, 2022 11:07 pm
Post by raymond88 Fri Mar 18, 2022 12:15 pm
Post by raymond88 Fri Mar 25, 2022 10:04 am
