Densen B-150 Plus Integrated Amplifier
Item: Densen B-150 Plus Integrated Amplifier
Condition: Item is in like-new condition. No dents or scratches. Comes with power cable and remote control.
Price: RM9500 or swap/topup
Can Trade-In your Amplifier/
Retail Price is RM20k
The new reference integrated amplifier from Densen is perhaps the most advanced integrated amp on the market. It is filled with advanced solutions, which all share the goal of giving you even more musicality and flexibility.The volume is controlled by an extremely precise attenuator made of Vishay metal film resistors, which is switched by relays controlled by the microprocessor. Compared to a normal volume potentiometer of the kind used in the majority of all preamps, the resistor network has virtually no self induced noise and an extremely low distortion. This results in an unsurpassed precision and refinement, and the attenuator contains no less than 200 steps! This makes it possible to adjust the volume very precisely (0.5 dB) even when the sound is so low that an ordinary volume control would create an uneven balance between left and right.The B-150PLUS output stage utilizes Densen’s unique ”DMCD” (Densen Mass Current Distribution) technology. The B-150 is, as with all other Densen amplifiers, The DMCD technology also secures an extremely firm grip on the speakers combined with a fast, precise and truly transparent sound. As the B-150PLUS is a wide bandwidth design it goes to 400.000Hz, resulting in improved slew-rate.The B-150PLUS is built using surface mounting techniques, and the components are mounted with a precision of 0.02mm (!) using silver solder. All solderings are made in an artificial atmosphere, consisting of nitrogen, to avoid oxidation of the solderings. The power supply is massive, consisting of a 750VA transformer and having a storage capacity of 130.000uF with 4 separate rectifiers, two of which are capable of 3.000VA. Unusually for an amplifier, not all of the capacitors are mounted in a capacitor bank, as some of them are located directly adjoining the output stage for faster power delivery. All resistors are laser trimmed metal film from Vishay with a precision of 0.1%. The B-150PLUS delivers 100W in 8 ohm and 200W in 4 ohm.The transformer is custom-made for the B-150PLUS, and is winded using a new technique. This technique reduces vibration from the transformer and therefore reduces mechanical noise from the cabinet. At the same time, this prevents mechanical vibrations from reaching the delicate audio signals on the PCB. It also works as an isolation transformer, thereby eliminating the need to use separate power conditioners.The special winding techniques used also ensure that the transformer modulates less than is normal (for other amplifiers) during the delivery of large amounts of current. Transformers normally lower the voltage during the delivery of large amounts of current which results in compression of the signal’s dynamics. As a result of the new winding method the transformer in the B-150PLUS is extremely stiff, which means that the voltage does not drop under large current deliveries.The printed circuit board is made of Teflon, and is double sided to allow for the signal on one side and the ground plane on the other, thereby optimising interference free signal transfer.The B-150PLUS contains sockets for the SB Board for surround, DP-03 and DP-06 MM and MC stages. There is also the possibility of upgrading the B-150PLUS with the DNRG external power supply to further enhance the sound quality, so as to experience truly breathtaking musical experiences. The B-150PLUS is also prepared for the SAXO electronic crossover, so that the B-150 can be used in active systems. This is done by mounting the crossover internally in the B-150PLUS in a socket. The SAXO crossover will fit all passive speakers on the market.The DenLink system implemented in all Densen products allows 2-way communication in multiroom installations. On the B-150PLUS, the link system will allow the user to power up a link amplifier in the kitchen, or another room, and then control the main system in for example the living room, sending the signals to and from the kitchen, for playback in another room. It will be possible to have full display information in another room, with status on all products. The DenLink / Multiroom system is also prepared for controlling the lights, so you will be able to dim them.
https://sightandsoundgallery.com/products/densen-b-150-integrated-amplifer
https://www.audioemotion.co.uk/densen-beat-b-150-plus-integrated-amplifier-20577-p.asp
https://soundgallery.com.au/product/densen-b-150-integrated-amplifier/
- Power output in 8 ohms: 2x100W
- Power output in 4 ohms: 2x200W
- Power supply size: 750VA
- Storage capacity: 130.000uF
- THD + Noise @ rated output: Less than 0.05%
- Frequency response (+0 -3db): 2-500.000Hz
- Weight/shippingweight: 14/15 Kg
- Product dimensions (WxDxH): 440x310x64mm
» densen B-100 Integrated Amplifier
» Densen DM 10 MK1 Integrated Amplifier (Sold)
» Densen B-110 Integrated Amplifier (Sold)
» Densen B-110 Integrated Amplifier (Used) - SOLD
» Densen DM-10 MK2 Integrated Amplifier (Used) SOLD
