Audio Research Reference 600 Power Amplifier
Audio Research Reference 600 power amplifier
(Used)
- Output power: 500 watts continuous at 16ohms,
20Hz-20kHz
(Typical power under average circumstances will be around 550 watts. Maximum power under ideal conditions will be around 600 watts)
- Power Bandwidth: (-3dB Points) 12Hz to 80kHz
- Frequency respond : 2Hz - 200kHz, -3dB, at 1W
- Input sensitivity : 2.0V RMS balanced for rated output.
- Input Impedance : 200K ohms balanced
- Output Regulation : Approx. 0.5dB 16 ohm load to open circuit (Damping Factor approx. 16).
- Overall Negative Feedback: 12dB.
- Power requirements: 105-125VAC 60Hz (210-250VAC 50Hz) 1600 watts at rated output, 2200 watts maximum, 800 watts at idle, 300 watts standby.
- Tube Required : 8 matched pair 6550C Power output; 4-6550C Regulators; 2-7233 Regulators; 2-6922 Regulator Amplifier; 2-6922 input.
- Condition : 8.5/10
- Dimension : 483mm (W) x 267mm (H)
x 749mm (D) Handles extend 38mm forward.
- Weight : 77.2kg/unit
Selling : RM48,000.00/pair
Payment : COD
Contact/sms: 016-423 3798
(Used)
20Hz-20kHz
Payment : COD
ksljaksa- New Member
- Number of posts : 3
Registration date : 2012-04-17
» Audio Research Reference 75 Power Amplifier (Used)
» Audio research VT 100 MK III power amplifier (Used)SOLD
» Audio Research V35 power amplifier (used) SOLD
» Audio research VT 200 power amplifier (Used)SOLD
