Audio Research Classic 30 stereo power amplifier (sold)
POWER OUTPUT
30 watts minimum continuous at 16 ohms from 17Hz to 20kHz with less than 1.0% total harmonic distortion. Typically below .005% at 1 watt. Approximate actual power available at "clipping": 32 watts (1kHz) (Note that the actual RMS power output is dependent upon both line voltage and "condition" ie: if power line has high distortion, maximum power will be affected adversely, although from a listening standpoint this is not very critical.)
POWER BANDWIDTH
(-3dB points): 15Hz to 50kHz
FREQUENCY RESPONSE
INPUT SENSITIVITY
.4V RMS for rated output
INPUT IMPEDANCE
100K ohms, nominal
OUTPUT TAPS
OUTPUT REGULATION
Approximately 0.4dB 16 ohm load to open circuit
OVERALL NEGATIVE FEEDBACK
19dB
DAMPING FACTOR
Approximately 23
DISTORTION
SLEW RATE
15V/µs
RISE TIME
3.5 µs
HUM & NOISE
Less than 0.5mV RMS - 93dB below rated output (20kHz bandwidth unweighted, inputs shorted)
POWER SUPPLY ENERGY STORAGE
Approximately 150 joules
POWER REQUIREMENTS
105-125VAC 60Hz (210-250VAC 50Hz) 300 watts at rated output, 400 watts maximum, 200 watts at "idle"
TUBE COMPLEMENT
(2 matched pairs) 6550 power output, (2) 6FQ7/6CG7 drivers
DIMENSIONS
19" (48 cm) W (standard rack panel) x 7" (18 cm) H x 14½" (37 cm) D (front panel back). Handles extend 1 ⅝" (4.1 cm) forward of the front panel. Output connectors extend 1" behind rear panel.
CONDITION: 7.5/10
PRICE : sold
FOR MORE DETAILS PLEASE CALL OR WHATAPPS
018-9742567 YANG
016-5968723 YUAN
POWER BANDWIDTH
FREQUENCY RESPONSE
INPUT SENSITIVITY
INPUT IMPEDANCE
100K ohms, nominal
OUTPUT TAPS
OUTPUT REGULATION
19dB
DAMPING FACTOR
Approximately 23
DISTORTION
SLEW RATE
15V/µs
RISE TIME
3.5 µs
HUM & NOISE
POWER REQUIREMENTS
TUBE COMPLEMENT
DIMENSIONS
CONDITION: 7.5/10
PRICE : sold
018-9742567 YANG
016-5968723 YUAN
YUAN- Frequent Contributor
- Number of posts : 135
» Audio research classic 60 power amplifier (Used)SOLD
» PS Audio Classic 250 Stereo Power Amplifier (Used) SOLD
» Audio Research D-79C tube stereo power amplifier (Used) SOLD
» Audio Research Hybrid Stereo Power Amplifier HD220 (Sold)
» Audio Research VT130SE tube stereo power amplifier (sold)
