Shunyata Delta NR Power Cord (SOLD)
I am selling of my Shunyata Delta NR Power Cord come with box 1.75Meter. It look new and i just plug there and not move it. Sell it due to upgrade
here is the spec:
Equally important, Delta NR also touts Shunyata's Kinetic Phase Inversion Process (KPIP) – a groundbreaking conditioning process that not only eliminates the need for time-consuming burn-in on your end but elevates the overall fidelity of your system. You will experience more detail, harmonic depth, and dynamic subtlety when listening to music with Delta NR in your setup. And you won't have to wait hours for it to happen. Delta NR is ready to go out of the box.
Built in the U.S.A., Delta NR cables are comprised of ultra-pure OFE copper woven into proprietary VTX hollow-core conductors linked to CopperCONN connectors. The latter contain pure copper contacts that claim higher conductivity principles than the common plated brass and bronze contacts found in almost every other cable at this cost. Advanced fluorocarbon dielectrics and sonic welding that mitigates junction points round out a cable whose noise-reduction capabilities can actually be measured. Hear the differences for yourself with a risk-free in-home audition backed by our 100% Music Direct Satisfaction Guarantee.
"Shunyata Research Delta power cords are possibly the most 'now' thing you can use in audio. Thanks to a lot of products with cheap and nasty switch-mode power supplies pumping nasties into your local mains, good audio is fighting a losing battle for sound. Delta fights in your corner."
– Alan Sircom, Hi-Fi+
KPIP (Kinetic Phase Inversion Process)
Shunyata founder Caelin Gabriel developed KPIP after years of research into the underlying causes of various effects such as burn-in, wire directionality, and cryogentic treatment. He discovered an underlying core principle that burn-in and cryogenics only partially addressed. Once the governing principle was understood, it became possible to create a processing technique and machine that could virtually eliminate the need for burn-in and cryogenic treatment.
CopperCONN Connectors
Many audiophile grade connectors are made from brass or bronze. Wile some may get a plating of silver, gold, or rhodium, the majority of the current is carried by the contact's base metal. CopperCONN connectors are with pure copper contacts, which have much higher conductivity that brass. The difference is clearly audible.
Highest-Purity Copper for Supreme Conductivity
OFE Alloy 101, or C10100, is the highest grade of copper, with a minimum 99.99% purity and a conductivity rating of 101% IACS. OFE stands for oxygen-free electrolytic and supersedes the term OFHC (oxygen-free high conductivity). C10100 is the only grade of copper that comes with a written certification of purity.
here is the spec:
Save 25% on "The Most ‘Now' Thing You Can Use in Audio": Shunyata Delta NR Power Cable (15A) Offers Groundbreaking Price-to-Performance Value, Built-In Noise-Reduction Filters
Now available for 25% off list price, Shunyata's price-to-performance-leading Delta noise-reducing (NR) power cables extend the company's relentless quest to implement cutting-edge, science-based technology in the name of great sound. Tailor-made for amplifiers and source gear, and distinguished with an "NR" designation, 10-gauge Delta NR cords incorporate onboard CCI noise-reduction filters that simultaneously help defeat both analog and digital noise – and which provide power conditioning to each individual component.Equally important, Delta NR also touts Shunyata's Kinetic Phase Inversion Process (KPIP) – a groundbreaking conditioning process that not only eliminates the need for time-consuming burn-in on your end but elevates the overall fidelity of your system. You will experience more detail, harmonic depth, and dynamic subtlety when listening to music with Delta NR in your setup. And you won't have to wait hours for it to happen. Delta NR is ready to go out of the box.
JohnTeh- Club Member
- Number of posts : 34
Registration date : 2021-07-28
» Shunyata Delta NR power cord (Sold)
» Shunyata Research Delta Power Cord (SOLD)
» Shunyata Delta NR Power Cord 1.75meter
» Shunyata Research Hydra Model 6 and Delta NR power cord C19
» Shunyata Power Cord - SOLD
