Exposure XM5
Exposure XM5
RM6850
The Exposure XM5 is a neat and well-equipped integrated amplifier that does nearly everything the contemporary music lover might desire. Sound quality is as ever highly dependent on finding a good match on the loudspeaker front, and while the XM5 doesn’t have vast reserves of power, meaning you have to be a little more careful than usual, get the speaker selection bit right and this Exposure should provide many moons of listening pleasure.
Speaker Output Specifications
Power Output (1KHz) : 60 Watts per channel into 8 ohms
Total Harmonic Distortion : <0.01% at 1KHz, rated power
Frequency Response : 20Hz - 20KHz +/- 0.5dB
Channel Separation : >60dB @ 1KHz AUX 2 input open (shorted > 80dB) >40dB @ 20KHz AUX 2 input open (shorted > 63dB)
Pre Amplifier Specifications
Pre Amplifier Ouput : Gain +12dB
Total Harmonic Distortion : @ 1KHz: & 1V ouput : 0.002%
Signal to Noise Ratio ref 1KHz & 1V ouput : >100dB, A weighted
Channel Separation @ 20KHz : >62dB input shorted > 41dB input open AUX 2 input
Input Specifications
AV input fixed level : 450mV @ 1KHz > 12K ohms S/N > 100dB
AUX/PH input MM : 2.5mV @ 1KHz, 47K ohms S/N 70dB
AUX 2 input Line : 350mV @ 1KHz > 14K ohms S/N > 100dB
SPDIF inputs BNC Coax & Optical : 32 - 192KHz @ 16-24 bits
USB input : Linear PCM 44K1 - 192KHz @ 16-24 bits DSD x64 (DoP) Asynchronous transfer from host
General Specifications
Mains Supply : 110/120V or 220/240V @ 50/60Hz (factory set)
Power Consumption : 200W both channels driven, 8 ohms load
Dimensions (WxHxD) : 218mm x 89mm x 363mm (inc knob)
Net Weight (unpacked) : 5kg
Gross Weight (packed) : 6kg
CALL JOSEPH FOR MORE INFO AT 0102001992
VISIT
Joai- Regular
- Number of posts : 65
» Exposure XIX / 19 Preamp & Exposure Super XVIII / 18 Power Amp Combo
» Exposure 7 preamp, Exposure 6 power supply.(sold)
» Exposure 2010 Integrated amp and exposure 2010 power amp SOLD
