Grimm Audio: CC1 Master Clock
Item: Grimm Audio CC1 Master Clock
Condition: 8/10. Item is in excellent working condition.
New is $2995 USD
Price:RM6800 RM5450 or swap/topup
Grimm Audio CC1 Master Clock Features
Ultra-low jitter clock source
16 word clock outputs
AES/EBU reclocking
Sample rates from 44.1kHz up to 192kHz
Two independent sample rate groups
Grimm Audio CC1 Master Clock Specifications
Word clock input impedance 75 Ohm.
Word clock input sensitivity better than 1Vpp.
Word clock output impedance 75 Ohm or 25 Ohm (low) on selected channels.
Word clock output voltage, terminated 2.7 Vpp, unterminated 5.5 Vpp. DC coupled.
Latency word clock in - word clock out: adjusted to less than 50 ns, but may be larger due to input clock jitter.
Internal intrinsic clock jitter 0,6 ps RMS (above 10 Hz).
Clock frequency master mode: 1, 2 or 4 times 44.1 or 48 kHz ± 10 PPM, 5 - 50 °C.
PLL performance (slave mode): 90 dB attenuation @ 10 Hz, improving at 60 dB/dec above that.
Pullability of clock frequency: ± 50 PPM (conform AES11 Grade 2).
Maximum ambient temperature for operation: 50°C.
Life expectancy power supply electrolytics > 45.000 hours.
Power supply voltage range +/- 20%
Fuses:
120V (USA): fuse 500mA
100V (Japan): fuse 500mA
230V (EU): fuse 250mA
Weight: 4 kg
Dimensions: 430 x 200 x 44mm.
Power consumption: 15 W.
Wood type of front: Abachi.
https://www.analogueseduction.net/streamers-music-servers-media-players/GRIMMclock1.html
https://tapeop.com/reviews/gear/75/cc1-master-clock/
https://www.soundonsound.com/reviews/grimm-audio-cc1
https://www.frontendaudio.com/grimm-audio-cc1-master-clock/
https://reverb.com/item/49324694-grimm-audio-cc1-master-clock
New is $2995 USD
Price:
The Grimm Audio CC1 Master Clock, owing to a radically redesigned discrete crystal oscillator, clock stability betters that of even the best test equipment available. The Grimm Audio CC1 is the ideal premium house-clock master clock generator for professional and project studios, alike. Make your digital sound it's best with the Grimm Audio CC1.
The Grimm Audio CC1 Master Clock brings the incredible clock stability of the AD1 to your current setup! The CC1 accepts Word Clock and distributes a super high quality Word Clock and AES/EBU sync to all equipment in your system. Now, any studio can benefit from some of the features of our AD1s unique sound quality like ultimate musical timing and stability of tone. Grimm Audios extensive research into the correlation between jitter and sound quality brought to light that emotional response to music is vastly more sensitive to jitter than previously realized. Attention turned from making jitter low to achieving the most stable clock possible. This research turned up a surprising array of previously underestimated performance factors like power supply noise, oscillator control circuit noise and low-level crosstalk. Owing to a radically redesigned discrete crystal oscillator, clock stability betters that of even the best test equipment available. To sync to an external reference the CC1 sports a PLL offering an astounding 90dB of jitter suppression at 10Hz, further improving at 60dB/dec. The CC1 offers base rates of 44.1kHz and 48kHz and 1/2/4 multiples in separately selectable groups, in addition to an AES/EBU reclocker for cleaning the digital feed to your DA converter. Like all Grimm Audio products, the CC1 features striking styling and solid build quality.Grimm Audio CC1 Master Clock Features
AES/EBU reclocking
Fuses:
Weight: 4 kg
» LHY Audio OCK-2 Master Clock Generator
» Esoteric G-03X master clock (used)
» Audio-GD Master 10 (used)
» Esoteric G-03X Master Clock Generator (Sold)
» Brik Audio Power Master (New)
